20 Most Recent
Hughes SDHBH DirecTV DTV Receiver Questions & Answers
Satellite dishes wen down during
Yes,unplug,replug the box back like about an hour later.The box,will reboot and updated it software.The incomming broadcasting signal should be back.If not storm,did more damages to the LB reciever connected on the dish itself.Must call Dish Network to check it out,might have to replace it.
Remote no longer pogrammed to
You may have flat battery of remote controller. Just replace with new ones and re do you programming.
If is not work, Your remote was defective and repairing at shop.
Regards, Jay
My remote isnt working due to the fact the
Hello
Just check one amoung the following codes.
.............. [0632]
............................ [0638] [0629] [0630]
........................... 0641 0621 0607 0580
Cyberhome DVR 1600
try
http://www.amazon.com/gp/help/seller/at-a-glance.html/002-2900108-9100062?ie=UTF8&seller=A1SJV7Q7GQM4PE
also
Hughes direct tv receiver (director pack)
get new ones i just had 2 boxes replaced 1 was sd-hbh and the other was a hi-def box both were fried cause the nit wit that set up the system didn't ground the dish and we got a lightning strike that fried them.... i would call direct tv or whoever your sat provider is because mine were replaced for free with 2 brand new boxes.... and you should check to see if your dish is grounded it will usually be grounded to a water pipe somewhere in the area of where your multi-switch is located
Searching for Satellite
The voltage is supplied by the power-supply through the RF/IF interface usually encased in a metal box on its own. Also without knowing the model number of your unit I cant help any further.
