20 Most Recent MGE Galaxy 3000 UPS System Questions & Answers
3answers
I had problem with my MGE Galaxy 30KVA. The
I have a temperature fault in my galaxy 3000. Try to clean the radiator behind the cabinet with the air compresor and clean all the fan inside so air circulation is good. Don't know about batt temperature fault. Hope this help.
8/17/2022 7:26:48 PM • MGE Galaxy 3000... • Answered on Aug 17, 2022
Self test error
Is the UPS in Bypass? Is the Inverter running? What alarms other than that code are on? Have you shut the unit down. Its best to call MGE, that unit requires to have software to work on it. Even though you find the problem, and replace the board, the Board needs to be program to that unit. YUP! This way MGE always makes money on the UPS's no matter where and no matter how old the UPS is. They lock you out. Which is unfair for the customer. The customer has no choice but to call the dealer to fix it. Trust me.. Then again when a customer buys a product, isn't it his for life? Why can't he fix his ups or hire whoever he wants besides the Manufacture? Wrong, NOT WITH MGE Products. I guess it's Job Security for MGE. That one positive thing.
3/9/2022 9:29:50 PM • MGE Galaxy 3000... • Answered on Mar 09, 2022
2answers
MGE Galaxy 3000 UPS shows charger internal fault .
mge galaxy 3000 battery circuit breaker shut off when normal power shut off too.plz help !!!!!!
6/10/2021 10:50:50 PM • MGE Galaxy 3000... • Answered on Jun 10, 2021
3answers
We at CAAP Davao Philippines have a MGE Galaxy
On the Galaxy display you could see what is the remaining battery life time as calculated by the software. Normally after you replaced the batteries you are supposed to reset this counter using specific software by the manufacturer. According to your information you have replaced the batteries 3 times in 5 years period. This is not normal. Nevertheless since the last replacement in 2008 it appears that the battery are now reaching the end life, which is generally 3-5 years life expectancy.
I would review the following of the assumption that the UPS is fully operational and the charging system is working.
1. Do a load test or a battery impedance test to verify the batteries are good
2. I would look at the battery life time specification, whether it is 3-5 years, 5-7 years ect.
3. Check the room temperature, every 10 degrees Celcius above 25 deg reduces battery life time by half
4. Check the number of power failures/ duration of these power failures and if possible what load were on the UPS at the time of the power failures.
I hope this will help. If all verifications are to specifications, then most likely it is a software problem
1/18/2021 11:55:37 AM • MGE Galaxy 3000... • Answered on Jan 18, 2021
Rectifier internal fault
check scr,check diodes,check driver cards
9/3/2018 6:43:55 PM • MGE Galaxy 3000... • Answered on Sep 03, 2018
3answers
MGE Galaxy 3000 UPS, do i require to reconfigure
No you don't have to reconfigure the UPS after battery replacement. However you may have to reset the battery Timer. There are 4 possible ways.1. Press and hold the fault reset button for 3-5 seconds2. Press and hold the fault reset and security key simultaneously for 3-5 seconds3. Press an dhold the fault and alarm silence buttons simultaneously for 3-5 seconds4. Cycle the logic Power. This means to remove power from the main processor.5. Call MGE. They have the software to reset the battery replacement alarm
6/27/2018 4:24:22 AM • MGE Galaxy 3000... • Answered on Jun 27, 2018
2answers
Cannot change ups mge galaxy 300 licence deadline
you can send me the executable file at [email protected] AND IWILL SEE IF THERE anything to do
2/3/2016 2:22:58 AM • MGE Galaxy 3000... • Answered on Feb 03, 2016
AC N fuse blown
The AC rectifier section circuit inside it has short circuited component/s. Contact any service technician. This is not a user repairable work. http://electronicshelponline.blogspot.com/
8/26/2015 1:53:03 PM • MGE Galaxy 3000... • Answered on Aug 26, 2015
2answers
Hi How many batteries installed in mge galaxy 3000
Configurations vary, do you have a model number you can provide?If you need any UPS help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website www.psihq.com
3/10/2015 6:18:24 AM • MGE Galaxy 3000... • Answered on Mar 10, 2015
Tharmal overload
MAY BE YOU HAVE MISS CONNECTED THE TEMPERATURE SENSOR.
2/4/2015 12:36:16 PM • MGE Galaxy 3000... • Answered on Feb 04, 2015
GE LP33 30KVA output power fails when main goes out
if INVERTER IS ON, WHEN MAINS GO OFF IF UPS FAILS AT THE SAME MOMENT YOU NEED TO REPLACE ALL BATTERY SET
2/4/2015 12:34:06 PM • MGE Galaxy 3000... • Answered on Feb 04, 2015
What batteries go in this unit how many 12? need a replacement
8.3 Battery Configurations
There are different configurations for different battery types and backup time. Here, the batteries from VISION and
YUASA are selected. The backup times ranges from 1hours to 4hours for 20KVA UPS and from 1hours to 2hours
for 30KVA UPS, because of limitation of CLA power rating.
UPS Backup
time Number of blocks Type of blocks Capacity(10H)
1h 1×24 6FM55SGX 52Ah
10kVA 2h 2×24 6FM45X 2×42Ah
4h 2×25 6FM75X 2×74.5Ah
1h 24 6FM75X 74.5Ah
15kVA 2h 3×24 6FM45X 3×42Ah
4h 3×25 6FM75X 3×74.5Ah
1h 1×25 6FM90X 90Ah
20kVA 2h 3×25 6FM55X 3×52Ah
4h 2×26 6FM150X 2×144h
1h 2×25 6FM75X 2×74.5Ah
30kVA
2h 3×24 6FM100X 3×96Ah
Sheet. 4 the battery configuration with VISION battery
UPS Backup time Number of
(10H)
1h 2X24 NPL24-12 2X24AH
10kVA 2h 2×26 NPL38-12 2×35.3AH
4h 2×26 NPL65-12 2×60.5Ah
1h 1×27 NPL65-12 60.5Ah
15kVA 2h 2×24 NPL65-12 2×60.5Ah
4h 3×26 NPL65-12 3×60.5Ah
1h 1×27 NPL100-12 92Ah
20kVA 2h 2×24 NPL100-12 2×92Ah
4h 4×26 NPL65-12 4×60.5h
1h 3X24 NPL65-12 3×60.5Ah 30kVA
2/4/2015 12:26:02 PM • MGE Galaxy 3000... • Answered on Feb 04, 2015
How to troubleshoot galaxy 3000 mge ups system 30 kv
you need the soft tuner software for G3000
2/4/2015 12:09:52 PM • MGE Galaxy 3000... • Answered on Feb 04, 2015
I have an error 2-4-6
code 2-4-6 does not exist. Code 4-2-6: Personalization code is not the some on the 3 boards.
Problem locating: That's an internal failure, control GDEx, MIZx, CHAx.
2/2/2015 12:32:00 PM • MGE Galaxy 3000... • Answered on Feb 02, 2015
Hello, our MGE GALAXY 3000 20kva, front panel
you need an MGE expert engineer to check on the internal components, maybe the display by itself it dead can be replaced while UPS is on no problem. if you want to switch off the UPS you go for force shutdown but I cannot guarantee will restart if you do not fix the fault.
2/2/2015 11:19:53 AM • MGE Galaxy 3000... • Answered on Feb 02, 2015
The lotr/litr board is faulty
replace it with the same part number.
2/2/2015 11:15:38 AM • MGE Galaxy 3000... • Answered on Feb 02, 2015
What is the price of 100AH capacity batteries?
You do not need a battery, you need many. You need knowledge to replace these batteries in a safe manner. Then you do not know where to buy batteries should ask a company for help ...
1/23/2015 8:34:23 AM • MGE Galaxy 3000... • Answered on Jan 23, 2015
What coolant liquid use the MGE Galaxy 3000 UPS System 10 kva
What????? No coolant liquid is ever used in any type of UPS. EVER
10/7/2014 6:16:05 PM • MGE Galaxy 3000... • Answered on Oct 07, 2014
Computers & Internet Logo
79 questions posted
Top MGE Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MGE Computers & Internet
Most Popular Question
mge galaxy 3000 ups shows charger
  • Computers & Internet
