20 Most Recent Horizon Fitness Horizon Motor T51 (treadmill) Questions & Answers
Horizon t51 control board wont light up or beep but power lights comes on
Its probably shot....treadmilldoctor.com and usedtreadmillrepairparts.com has parts for this machine.
7/21/2020 2:39:16 PM • Horizon Fitness... • Answered on Jul 21, 2020
The motor will not move
test voltage from output control board motor, for input voltage terminal motor, if there ARE not voltage, the control board is faulty. see my personal TIPS for motor.2) test the terminal voltage motor, if there ARE the motor is faulty.3)loose the belt and try again if the motor is running the problem is the deck belt board, LUBE it.God bless you356531a7-34d7-49c5-b4b2-83d2982da514.gifafae3425-f7ac-48a8-b373-2402f885bb57.jpg
10/16/2013 11:33:05 AM • Horizon Fitness... • Answered on Oct 16, 2013
I have a horizon fitness
hi,
from ur description i think ur treadmills control module have problem. motor driving card and motor is ok. normally there are no serviceable part inside the controlling module ( user interface module). only thing can do is remove the controlling module, take out its board check all the micro switches( press button switches) replace it found faulty or not( remember to remove the power before). the refix it and the test the tread mill.
ok
12/26/2010 6:06:21 PM • Horizon Fitness... • Answered on Dec 26, 2010
I just bought a secondhand
the motor controller is shot and will need replaced.
8/10/2010 9:03:22 PM • Horizon Fitness... • Answered on Aug 10, 2010
0answers
2answers
Horizon Fitness Treadmill new motor starts but cuts out in less than 5 seconds
Sounds like a faulty motor starter if equipped or motor it self faulty. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
3/8/2016 3:34:12 AM • Horizon Fitness... • Answered on Mar 08, 2016
0answers
0answers
0answers
I cannot adjust or reset the speed on the console as it just goes straight onto the fastest speed every time I start it up and even if you adjust the speed and/or the programme it still starts in the
Hey Tyler, You may need to re-calibrate your treadmill you can check out this video http://www.youtube.com/watch?v=MWDvxTKXem0 it will guide you through it. if the problem reoccurs after the calibration then you may need to replace the speed sensor... it is usually located next to the drive motor pulley (it is a magnetic pulse speed senor so it should be facing the magnet on the motor pulley) P.S. if the sensor is not lined up this can be the cause of the problem also, so check that it is before replacing. Hope this help... Enjoy
4/20/2014 7:50:07 AM • Horizon Fitness... • Answered on Apr 20, 2014
2answers
Treadmill displaying temperature over for an mbh
The cause of this problem is because your powerboad need big power (Amp) to turn the motor (and the belt) This usually happens if your treadmill belt is not lubricate well or needs change. So, first try to lubricate your treadmill belt with silicone oil and be sure that treadmill deck is clean. If the problem continues you must change your treadmill belt. Greetings from Greece
10/22/2013 10:24:40 AM • Horizon Fitness... • Answered on Oct 22, 2013
My Horizon T101 treadmill is about two years old
please see the video and lube the rollers bearing front+ back with grease.God bless you
10/15/2013 12:02:36 PM • Horizon Fitness... • Answered on Oct 15, 2013
Horizon Fitness Horizon Motor T51 (treadmill) Logo
9 questions posted
Top Horizon Fitness Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Horizon Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Horizon Fitness Exercise & Fitness
Most Popular Question
horizon t51 control board wont light up
  • Exercise & Fitness
