20 Most Recent LifeSpan Fitness TR1000HRC Treadmill FREE Inside Delivery! Questions & Answers
2answers
Hi i have a e7 code on my lifespan fit e3i elliptical help please
For E6 and E7 codes, while this code is displayed: First, press and hold Level Minus, then the Start key (the Level Minus key first), for 2 seconds. (make sure you press Level Down a little before Start.) The console should beep twice; the display does not change. If the potentiometer value on the left of the screen is higher than 240, press and hold the Ramp minus key to lower the ramp until the value is in a range between 48 and 240. Then release the button. May reset by itself now. Or, turn the elliptical off and back on to reset. If ramp goes up to 255 and won't move in any mode, unplug power for 20 minutes. If the potentiometer value is lower than 48, press and hold the Ramp plus button to raise the incline until the value is in a range between 48 and 240. Then release the button. May reset by itself now. Or, turn the elliptical off and back on to reset. Now press Start, and pedal for 30 seconds. The ramp should reset to zero, the lowest level.
7/7/2022 7:45:55 PM • Lifespan... • Answered on Jul 07, 2022
Recumbent bike. Why can't I clear R5i E1 error?
CHECK WITH THE MANUFACTURER'DS WEBSITE . WE DO NOT KNOW EVERY PEICE OF EQUIPMENT MADE WORLDWIDE
11/9/2020 7:30:44 AM • Lifespan... • Answered on Nov 09, 2020
I have got E06 error in Lifespan Treadmill.
I have read that the speed sensor near the front flying wheel connected the front roller, sometimes get malfunction. I have just tapped it gently with a screwdriver and this seems to have done the trick. Hope this will help somebody with a similar situation.ElseCall Vision Fitness Customer Service, they'll help you reset the treadmill by using the console. This will help clear the problem. I've been told that this error occurs when the incline controls are not used often. I've cleared the error using their instructions but after several months it does reoccur. And no I don't use the incline option often so that might explain it
9/6/2019 4:25:46 AM • Lifespan... • Answered on Sep 06, 2019
Lifespan treadmill error 9
call maintenance.
10/28/2018 5:57:18 PM • Lifespan... • Answered on Oct 28, 2018
I have a Lifespan Torque II treadmill coming up with a E03 error message. What do i need to do to fix this?
LifeSpan TORQUE II Owner Manual I checked the Owner manual and only found error codes E01, E02, E05, and E08. I have attached a link to the manual but would suggest you call a local dealer for assistance with E03 code. Good luck. Semper Fi, Z
2/20/2018 4:53:33 PM • Lifespan... • Answered on Feb 20, 2018
tip
Treadmill Error Codes and Troubleshooting
Please refer to the following treadmill troubleshooting guide if your LifeSpan treadmill or treadmill desk is displaying an error code. If after trying the suggested solutions your treadmill is still showing an error please contact our customer service department at 877.654.3837 x4 or fill out a customer service request form.
Error
Solution
E1 An E1 error code is a very broad code. It is important to know when the E1 occurs and what was being done when it occurred. An E1 code just means that the console is not getting a reading from the reed switch (Speed Sensor). If the running belt moves for several minutes and then produces the E1 error, this is most commonly a result of the running belt needing lubrication. The motor control board will shut down due to the motor pulling too much current, triggering a safety shut down. It is important to maintain a proper lubrication schedule for your treadmill. The lubrication frequency will vary depending on the model, please refer to the lubrication instructions in the owner's manual. When lubricating be sure to use a 100% silicone non-aerosol treadmill lubricant, applying 1-oz. After lubricating the running belt, if you still continue to have problems or it returns after just a few weeks, the running belt may have become glazed. This is a term used that describes the pores on the underside of the running belt closing due to excess friction. When this occurs, the running belt can no longer absorb lubrication. In this instance you may need to replace the running belt as continued use can lead to damage of other components such as the motor and the motor control board. If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the speed sensor needs adjusting/replacing or the main wire harness is damaged. If there is no belt movement, or you notice a burning smell coming from the motor area, this may be an indication that the motor or motor control board has become damaged. Without lubrication, continued use can cause damage to the motor and/or the motor control board which may require replacing of these components. If needing to replace either of these components, it will likely be necessary to replace the running belt as well. Doing so will prevent friction from damaging the newly installed components or other components in the machine. Watch our one-minute tutorial on the easiest way to lubricate your treadmill belt.
E5 The E5 Error is specific to the TR2000e and the TR3000e treadmills. The error code triggers when an object is detected by the folding sensors on the underside of the treadmill. The folding sensors look like small trapezoids: two on the back and two on the front. Make sure there are no foreign objects underneath the treadmill. If no objects are present, inspect the sensors for damage. If the problem persists, please contact customer service.
E6 or E7 An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjusted.
  1. Turn the power OFF, wait 5-seconds and turn back ON.
  2. Get into test mode and enter through the I/O testing step. This screen will display the potentiometer value of the incline motor. Different models will have different values. Check to see if the running deck is raised to high incline level or if it is at the low level. If the running deck is at a low position press the incline up button. This will cause the incline motor to raise the running deck up. When the deck gets to a mid-level position, press the incline up button a second time to stop the deck. If the running deck is in a high incline position, use the incline down button to adjust the deck to a mid-level position.
  3. Once the unit is in the mid-level position, power the treadmill off for 5-seconds and then power it back ON.
  4. Start the treadmill.
  5. Once the treadmill starts the running deck will move to the level 0 position. If this does not resolve the issue or it will not adjust please contact customer service.
Also note that not all models will have the ability to adjust the incline motor. If the adjustment procedure is not found in the Owner's Manual then contact customer service.
E9 or E10
  1. Power OFF and ON.
  2. If the error code is still shown please contact customer service.
Uart
  2. If the error is still shown, check to make sure the wires are properly connected.
  3. If the wires are properly connected and the error is still shown please contact customer service.
AC/DC-1
  1. Power OFF the treadmill for 5-minutes and then turn back ON.
  2. If the error is still shown, turn the treadmill OFF and unplug from the wall outlet. Find the cable that goes between the board under the motor cover and the console. Unplug any connections and replug.
  3. If the error code is still shown please contact customer service.
AC/DC-2
AC/DC-3
AC/DC-4
  1. The motor is drawing too much power from the motor control board.
  2. Lubricate your treadmill with 1 oz. of the 100% silicone non-aerosol lubrication.
AC/DC-5
AC/DC-6
AC/DC-7
AC/DC-8
  2. If the error is still shown, check if the upper and lower control cables are connected properly and if the safety key is inserted completely.
AC/DC-9
Treadmill Error Codes Troubleshooting
on Dec 10, 2017 • Exercise & Fitness
2answers
Treadmill
DEAR IF IT STOP AFTER 6 OR 8 SECOND YOUR SPEED SENSOR IS NOT FIX AND ITS OUT OF SERVICE YOU MUST FIX IT SIMPLY AND YOUR TREADMILL WORK AS WELL you can countiue contact us with smart phone on wattsapp or telegram by : +989195116738
4/19/2017 12:23:05 PM • Lifespan... • Answered on Apr 19, 2017
2answers
DC-8 error code on a Life Span Tr1200i
I'm getting a dc 8 code while running. Then it stops. What's causing this?
2/22/2017 9:30:51 PM • Lifespan... • Answered on Feb 22, 2017
Were can I find a wiring diagram for my lifespan sprinter xl treadmill
If you wish to get some details; check the site linked here. Pull up older posts.... http://electro-medical.blogspot.com/
6/20/2016 4:36:16 PM • Lifespan... • Answered on Jun 20, 2016
0answers
How do I fix e03
Be the first to answer 11/14/2015 10:24:31 PM • Lifespan... • Posted on Nov 14, 2015Be the first to answer
0answers
Lifespan TR 1200i Treadmill Theres a creaking noise coming from inside the main covered (engine) compartment when I walk fast and run. I've taken the cover off and can't figure out what is causing th
The LifeSpan TR1200i Treadmill can have a little bit of flex in the frame when being used on wood floors or carpet. With the large plastic hood tightened down securely, the flexing causes squeaks. Further tightening can cause unwanted deformation of the hood leading to breakage. The cure is to loosen the 4 screws that bind the hood to the frame until the hood is sitting on the screws without binding. The weight and size of the hood will keep it in place.
4/24/2015 1:04:58 AM • Lifespan... • Answered on Apr 24, 2015
LifeSpan Fitness TR1000HRC Treadmill  FREE Inside Delivery! Logo
4 questions posted
Top Lifespan Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Lifespan Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Lifespan Exercise & Fitness
Most Popular Question
e7 code lifespan fit e3i elliptical help
