I have a Proform C
Dear Sir:
Hello , i want to help you:
1) You must check the receptacle is there are Voltage missing.
2) You must check in according with Treadmill is the machine operate in 115V- or 220-Volts AC, 60 hz.
3) You must use some VOM, for the check the voltage if you can not operate the VOM, you must check the plate in the Treadmill what voltage are using 115 or 220V, you can use some Lamp for table tha work with 115 Volts, for to proof. If the lamp doesnot light,some Breaker or Fuse is Open. Check the circuit closing the Breaker or replacing the fuse.
4) After you checking what voltages are using , you must conclude if the voltage in receptacle is o.k or improperly in according with the voltage of the Tradmill.
5)If the Voltages are O.K you must check in the Plug is some wire is loose, or contacts corroded.
6) Must check to the wire is broken from the plug .Replace or repair.
7) Check is the fuse or breaker of the machine is open. Replacer or testing again.
8) If there o.k You must check the rely or contactor from motor, if that corroded or dirty, for to clean or replace .
9) Check finally the motor , if work in 115 or 220 Volts,maybe some Animal byte the wires, and open the same, Replace the wires or repair.
Inform me if that o.k or i can help you more.
sincerely.
E. Cuadra
