20 Most Recent
Ranger RCI-6900F-150 CB Radio Questions & Answers
My rg 66 signal meater dont work and no sound till it worms up whats wrong
frequency drifting on last number really doesn't make much difference. Lets say you are on CH 1 26.965 and the counter says the frequency is 26.9648 . Its not right but it close enough that its not going to make a whole lot of difference .Signal meter not working is not a problem either . You have to check the schematic for what voltage operates the meter,check to make sure that voltage is there. If it is then you should change the meter., if no voltage then you should check for the solution as to how to get it back. When the radio warms up and you hear people talking take some freeze spray and give the audio IC a shot to see if it still works or not .
8/5/2015 6:08:40 PM •
Ranger...
Answered
on Aug 05, 2015
More power rf
turn it down to 1 may 1.5 watts and turn modulation up 95% and add a 500 watt liner to it and you are in business.
2/23/2015 5:33:05 PM •
Ranger...
Answered
on Feb 23, 2015
No power to radio
its called a reverse polarity diode,its black and near the electrical wires that come into set.
10/4/2014 7:54:22 PM •
Ranger...
Answered
on Oct 04, 2014
Spaltters all over the band
try turning the mic gain down for a start, if that doesn't correct it, sounds like the modulation gains have been maxed, and the transmitter mistuned
9/14/2014 7:52:06 PM •
Ranger...
Answered
on Sep 14, 2014
I have to keep my rf=gain turned all the way down
The RF limits the signal strength you radio receives. After setting the RF to limit excessive signals, then set your squelch up until the noise is gone. There are some areas which have high RF background noise so adjustments are made often while driving around. Use the ANL (automatic noise limiter) and other features also to control the noise.
2/28/2011 12:44:24 PM •
Ranger...
Answered
on Feb 28, 2011
SCI 6900 F.TURBO. BUZZING NOISE,
I am going to need a bit more information then that.
Does it do the same thing with other radio's?
Has any one been inside the radio?
The buzzing can be from either a rectifier in the power supply, or some times there is an issue on some 9600 boards that can cause a buzzing.
If its the power supply, then your receive will be poor because the buzzing is killing it.
12/14/2010 5:12:01 PM •
Ranger...
Answered
on Dec 14, 2010
I went to key up my ranger and i could not get it
Yes, a faulty mic can cause a radio not to transmit or receive. Try another mic and see if it works then. If it will not key up, it could be the final output transistor.
Does it receive?
10/12/2010 6:10:56 AM •
Ranger...
Answered
on Oct 12, 2010
RCI 2970
broken coax inside the radio going to the amp.. is the display ok? sometimes static from storms will knock out the processor and the radios will quit. have to replace the cb shop temple, tx on yahoo search processor board. to restore operation on that problem. is there more info can help us with?
12/8/2009 6:01:28 PM •
Ranger...
Answered
on Dec 08, 2009
The s-meter goes down scale when I am modulating.
the reason i saked is that if you turn the power all the way up it tends to reverse modulate. this happens because the power is using all the transmit voltage for the final and the modulation circuit is trying to use as much as it can so the radio is most likly out of alignment and needs to be realigned. its not that hard if you have the service manual and the correct equipment. i have a factory authorized shop and we do alot of realignments due to the cb shops tweaking the 10 meter radios.
3/13/2009 6:09:14 PM •
Ranger...
Answered
on Mar 13, 2009
I have a 6 wire D104 . How do I wire it to a Ranger 2985 dx ?
Wiring a 6-wire D104 microphone to a Ranger 2985 DX requires connecting the wires in the correct order and configuration.
The Ranger 2985 DX has an 8-pin modular plug, and the D104 microphone has a 6-pin modular plug.
Here's one way to wire the D104 microphone to the Ranger 2985 DX:
- Connect the red wire from the D104 to the 8-pin modular plug's pin 4 (PTT - Push-To-Talk).
- Connect the black wire from the D104 to the 8-pin modular plug's pin 5 (Ground).
- Connect the white wire from the D104 to the 8-pin modular plug's pin 6 (MIC + Audio).
- Connect the blue wire from the D104 to the 8-pin modular plug's pin 7 (Receive Audio)
- Connect the green wire from the D104 to the 8-pin modular plug pin 8 (Transmit Audio)
- Connect the yellow wire from the D104 to the 8-pin modular plug's pin 3 (UP-Down).
It's important to double-check the wiring configuration with the user manual of the Ranger 2985 DX and the D104 microphone. Some manufacturers have different wiring configurations and it's important to match the wiring accordingly to avoid any damage to the device.
It's also worth noting that if you are not comfortable with the wiring process, it's best to consult with a professional technician or a radio expert.
Led display
Hi John,Ranger CB YES, Model No. NO, led display, YES IT HAS ONE OF THOSE.More info please john.The more info about the radio you give and the problem, the easier it is to give you assistance, we can't answer buy guess work, it's neither helpful nor pleasant.Cheers,Peter
