20 Most Recent
Timex 1440 Sports Stealth 174 Wristwatch Questions & Answers
How to set time on MDC74571W
Hold lower right button, wait for beep, release.
Click lower left to scroll through all time settings.
Click upper right button to change time/date/year.
Click lower left to save/exit.
I can't change the time, my watch didn't come with
mcdevito75 here, You need 2 buttons to set your Timex, the MODE and SET buttons, first presss the MODE button, usually on the right side of the case, you may/maynot have to hold the MODE button down 2-3 seconds, now see display flashing, now press the SET button to set each functon, (hour, minute etc.) press MODE button after each function is set. After all functions are set, press MODE again to see steady display.
HOW DO YOU TURN OF
If its the 4 button watch, you hold in the bottom right, which sets it to alarm, and then press the top right button. It bleeps at each press and turns on/off the alarm display.
Need instruction manual for 1440 sports watch
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Battery replacement Timex T2H381
This will depend on the back of the watch. Totally smooth watch back is usually a push fit. Using a small precision screwdriver you Gently lever around the back plate until it 'Pops' off. the battery should hook out by CAREFULLY using the screwdriver you used to remove the back plate. *Note* check which way up the battery is fitted BEFORE you remove it. The back plate should just push on and should quietly click when seated correctly.
Some back plates are 'screw on'. You can usually spot these by the dimples or notches on the back plate where the removal tool fits.
Manual for timex TW4B02500CS
Instruction Manuals, User Guides and Downloads
timex.cahttps://www.timex.ca
Celebrating 165 Years of Innovation in Timekeeping. Discover More From Timex. Free Standard Shipping. New & Classic Styles. Styles: Metropolitan+, Waterbury, One GPS+, Weekender, Expedition, Intelligent Quartz, Originals. Shop Best Sellers.
Rating for timex.ca: 3.7 - 209 reviews
- Return policy: Most items 30+ days
Expedition North TitaniumBuilt With the Strongest Materials, Shop The Expedition North Titanium
Timex® New ArrivalsShop Our Newest Watches & Enjoy Free Shipping Worldwide.
Shop Marlin® Sub-DialA Modern-Retro Update To Our 1960s Marlin. Sharp Enough For Any Outing
Search Results
Watch Instructions & Manuals
Timex
https://www.timex.ca > watch-manuals
Instruction Manuals, User Guides and Downloads. Search for documentation for your Timex by entering the name, product number or feature. Sort by name ...
Timex M EXPEDITION GRID SHOCK WATCH, ... - manualzz
manualzz
https://manualzz.com > Fashion & style > Watches
View online or download PDF (301 KB) Timex M EXPEDITION GRID SHOCK WATCH, TW4B02500 Instruction manual • M EXPEDITION GRID SHOCK WATCH, TW4B02500 watches ...
I Don't know to set up of the TIMEX DIGITAL WR100M IRONMAN CLASSIC 100 THAT I JUST GOT/// HELP
A lot of watch manufacturers use the American style date layout of Month/Day/Year. Try this. Looking at the watch press and hold the bottom right SIDE button for 3 seconds. It should enter setting mode where the seconds display will flash. Press the Right FACE button once. It should switch to the Hour display flashing. Press the same button again to go to minutes and them again to go to the date display.
Repeated pressing of the top Right SIDE button changes the numbers upwards, (1,2,3,4), and the Left FACE button changes the numbers downwards, (4,3,2,1). Press the Bottom right SIDE button once to finish and go back to the normal display.
http://assets.timex.com/manual/W-9.pdf
