20 Most Recent Onkyo HT510 Receiver Questions & Answers
hi,
There is a standby transformer inside the Onkyo receiver at the mains input stage. If the standby transformer is faulty then the unit will not power on. There will be two transformers. One is big and the other is a small one. The small tarnsformer is the standby transformer. Which will be fitted on a small board where the power cable is connected. Replace the transformer to rectify this problem.
OK
Onkyo HT510... | Answered on Oct 17, 2011
HI,
Press the SPEAKER ADJUST button on the frond panel of the receiver. With this button you can select different parameters of the speakers. Using the PRESET/ADJUST button you can change the parameters.
ok
Onkyo HT510... | Answered on Sep 24, 2011
Tinkering won't work. HT510??? Not HTR510? Maybe that's what you meant.
All AVR's have settings for individual speaker channel levels and distances from the listening position.
http://filedepot.onkyousa.com/Files/own_manuals/HT-R510.pdf
Onkyo HT510... | Answered on Jul 12, 2011
The magnetic cartridge preamp should work with the turntable, as presumably it will have a magnetic cartridge in it. The only reason that the amp states "magnetic" is that some very old turntables have ceramic cartridges which should not be connected to that terminal. Even if the turntable had a "ceramic" it could be replaced with a magnetic one!
Onkyo HT510... | Answered on Mar 21, 2010
take an emery board to the battery contacts on the remote and lightly to the battery ends,at this low a voltage on these remotes any oxidation affects the voltage passed through the contacts to the remote even with new charged up batteries
Onkyo HT510... | Answered on Mar 09, 2010
get another speaher wire two wires are touching making ti go into protect mode..
Onkyo HT510... | Answered on May 18, 2008
Chances are that Time Warner is just plain wrong. That's what you get with free tech supp....oh, uh right. scratch that.
Your receiver seems to be receiving a 2-channel digital audio signal (PCM) from the cable HD box. With this type of input signal, you can't select Dolby Digital on the receiver.
If you have a Scientific Atlanta 8300 (or a closely similar model):
Press [Settings] button on the remote twice. This will open the General Settings menu. Go to "Audio: Digital Out" and the select Dolby Digital (by hitting [-> Move Right]).
If you have another type of cable box, just review the settings menus until you find something relevant to digital audio out and avoid PCM, stereo or "down conversion", but look for Dolby Digital, DTS or "All".
Please keep in mind, that when connecting devices via HDMI cables, your box may decide it's smarter than you and reset the format of the digital audio back to PCM. This is some possibility of this occurring if the cable box or TV is unplugged and plugged back in.
If you have problems, add the cable box make and model and let me know.
Onkyo HT510... | Answered on May 15, 2008
Hello
If you have the original remote
check the display button or dimmer button.
If you don't get any illumination from the display screen, that means that display florescent is at the end of life needs to be serviced.
Regards.
Onkyo Audio... | Answered on Sep 09, 2019
HI
Power Transistors
2SC5200
2SA1943
OR equivalent.
Good luck
Hello
Your AVR is in protection mode
Check Speaker cables if there is a short circuit or defected speaker. can also do the same thing.
If non of the above.
you need to service the AVR .
Good luck
Hello Brenda
Where do you want to hook your ONKYO and with what you want to connect it to.
There are several steps and a lot of devices can be connected to the Onkyo.
1 Speakers are to be connected on the rear side of the device. as it shows in and on the Instruction manual If you have it.
And for other devices each device has its way of connectors.
Optical to optical and RCA to RCA ...
IT depends on What kind of devices you have.
Hello Brian
1: connect your fire tv to any HDMI input on your Onkyo AVR.
Make sure you know which input and select it by the remote. or by the selector keys on the AVR front panel.
2: The HDMI output from the Onkyo AVR, goes to the HDMI input of your TV...
I hope its Clear.
Good Luck Plugging HDMI Cables.
Hello
Did you update the AVR over the internet?
If so the device wont work anymore.
You need to service the device in a nearest Onkyo service department.
Regards
Onkyo HT510 Receiver Logo
17 questions posted
Popular Products
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Audio Players & Recorders
Most Popular Question
onkyo ht510 receiver not turn
  • Audio Players & Recorders
