20 Most Recent Onkyo DTR7 Receiver Questions & Answers
No sound from back channels of my dtr-7 stereo receiver
Do a Factory reset. it's most likely a speaker setting issue. press VCR and wille holding it press the Standby button. once you see clear on the screen it is done. try it now!
11/11/2011 2:24:05 AM • Onkyo DTR7... • Answered on Nov 11, 2011
The video works but the audio does not work on
do a factory reset- wile on press vcr at the same time press and hold standby once clear appears on the screen you are done. this should fix it.
11/10/2011 4:44:36 PM • Onkyo DTR7... • Answered on Nov 10, 2011
When I turn on my Onkyo DTR7 receiver, I donot get
You must re-seat the HDMI board on and try. sometimes the connections come loose and causes the connection to the Relay trigger not to work.
11/10/2011 4:43:03 PM • Onkyo DTR7... • Answered on Nov 10, 2011
Sound suddenly disappeared on DTR7-both A+B
if you have narrowed it down to the receiver the thyristors are the most common cause
1/11/2011 4:31:54 AM • Onkyo DTR7... • Answered on Jan 11, 2011
2answers
Will not turn on...
try unplugging overnite
10/19/2008 11:57:27 PM • Onkyo DTR7... • Answered on Oct 19, 2008
0-83 error on onkyo tx nr 555
The 0-83 error indicates a problem with the firmware update. Try resetting the receiver's BIOS by following these steps2: Unplug all cables Un-Power the receiver Power the receiver Before the receiver gets into the "Enter for updating" message, press Tone + CBL/SAT + ON/STANDBY. This will show you either the volume numbers or get you into settings of the receiver's speaker configuration. Press CBL/SAT + ON/STANDBY. This will clear the BIOS and show a "Clear" message on the display. Wait until you hear a couple of clicking sounds for the receiver to turn on and off the power. TX-NR555 Owner's Manual - Onkyo Product Support (onkyousa.com)
2/26/2024 3:51:06 AM • Onkyo Audio... • Answered on Feb 26, 2024
2answers
Onkyo nr 555 stuck on recovery:NET
Hello Did you update the AVR over the internet? If so the device wont work anymore. You need to service the device in a nearest Onkyo service department. Regards
2/24/2024 6:24:24 PM • Onkyo Audio... • Answered on Feb 24, 2024
3answers
Onkyo skw 591 subwoofer...blue light is on and no sound? any thoughts?
Hello, To test the subwoofer when the blue light is on if you apply your thumb to the end of the subwoofer cable (the end that you would plug into the receiver) there should be feedback from the sub. If there is no feedback then the sub is not working correctly. Thanks, FJD
1/2/2024 2:06:41 AM • Onkyo Audio... • Answered on Jan 02, 2024
Part number of battery on onkyo digital board for TX DS-797
Here is service manual for your help. See the pat reference on IO Board and compare it with service manual. ONKYO TX-DS797 SERVICE MANUAL Pdf Download ' ManualsLib
12/31/2023 9:27:34 AM • Onkyo Audio... • Answered on Dec 31, 2023
Onkyo HT-R758 AV Receiver.
There are several causes of this problem. My be mute is ON, may be fuse is blown etc etc. However refer to page 62 of manual, it will help. HT-S6500_English_2022-11-02-204020_ivkn.pdf (onkyo-av.com)
12/11/2023 2:09:15 PM • Onkyo Audio... • Answered on Dec 11, 2023
Onkyo powered subwoofer SKW-791
Oknkyo SKW-791 has build in amplifier. So it can be connected through Line Out Connector of sansui amplifier. If speakers out is connected with subwoofer, the circuit board in subwoofer will be blown.
12/11/2023 2:03:09 PM • Onkyo Audio... • Answered on Dec 11, 2023
How do I hook my onkyo SKW-791powered subwoofer to my onkyo av receiver HT-R758
You need a RCA sub-woofer cable (analog mono) to connect between the receiver's sub-woofer Pre Out and the sub-woofer. This cable has a single RCA plug at each end of the cable. The cable is somewhat thicker than some audio RCA cables. You can use any RCA cable temporarily. The manual for the HT-R758 is available from Onkyo here: https://onkyousa.com/ht-r758 . The current link to the manual is https://assets.onkyo-av.com/product-manuals/HT-S6500_English_2022-11-02-204020_ivkn.pdf?v=1667421620 . See page EN-13 (page 13 of the PDF) for connecting to the subwoofer. The original package came with a 10' RCA sub-woofer cable, see page EN-1 (page 81 of the PDF) for the speaker list. I hope this helps. Cindy Wells
12/10/2023 12:09:43 AM • Onkyo Audio... • Answered on Dec 10, 2023
What's the error M1.04/19912A50?
The error code M1.04/19912A50 on your Onkyo AV receiver HT-R398 typically indicates a firmware or software-related issue. To resolve this problem and reset your receiver, you can follow these steps:
  1. Power Cycle the Receiver:
    • Turn off the receiver and unplug it from the power source.
    • Wait for about 10-15 minutes to ensure that all internal components have fully powered down.
    • Plug the receiver back in and turn it on.
  2. Factory Reset:
    • If the error persists after power cycling, you may need to perform a factory reset to restore the receiver to its default settings. Note that this will erase all your custom settings, so make sure to back up any important configurations if possible.
    • To perform a factory reset, refer to your receiver's user manual for specific instructions. Typically, this involves pressing and holding specific buttons on the front panel while powering on the receiver. The exact combination of buttons may vary by model.
  3. Firmware Update:
    • Ensure that your receiver's firmware is up to date. Visit the Onkyo website and check if there are any firmware updates available for your HT-R398 model. If updates are available, follow the provided instructions to update the firmware.
  4. Contact Customer Support:
    • If the issue persists after trying the above steps, it's a good idea to contact Onkyo customer support or visit their official support website. They may be able to provide specific guidance or solutions for the error code you're encountering.
Remember to consult your receiver's user manual for model-specific instructions, as the steps to reset or update firmware can vary between different Onkyo models. Additionally, be cautious when performing a factory reset, as it will erase all settings and return the receiver to its default state.
10/1/2023 11:51:04 AM • Onkyo Audio... • Answered on Oct 01, 2023
Onkyo HT-R320 Audio Video Receiver. Is there any hard reset feature
Question edited to correct all the typos! Onkyo support suggested I reset the unit by holding the video 1 button while pressing power to reset to factory default, which according to the Tech will reset the Logic controls of the unit. Sep 4, 2005
Problem with ONKYO HT-R320 receiver (HT-S570) - AVS Forum
https://www.google.com/search?q=Onkyo+HT-R320+hard+reset ..
9/9/2023 7:36:30 PM • Onkyo Audio... • Answered on Sep 09, 2023
Why is my Onkyo SKW-591 making a thumping sound?
The thumping sound might be originating from problems within internal parts, like capacitors or resistors, which could be contributing to the issue
8/31/2023 10:32:41 AM • Onkyo Audio... • Answered on Aug 31, 2023
My Onkyo TXSR393 receiver has no power will not turn on
Open up the case and look for a small glass fuse on the power board. Then you have to work out which component caused it to blow. Normally, you need professional service.
8/25/2023 6:28:48 PM • Onkyo Audio... • Answered on Aug 25, 2023
I have ONKYO HT-R997 which is in NG:LCR mode and have tried alot but no success yet. Need Help SOS Call
My Onkyo receiver is throwing up a code: NG
JustAnswer https://www.justanswer.com > home-theater-stereo > fl... Nov 29, 2020 - The NG error code usually refers to a short in the amplifier system or one of your speaker channels. First, please turn off the receiver. Please ... 1 answer ยท Top answer: Please visit this page to find your nearest service center https://www.onkyo ..
7/25/2023 3:55:48 PM • Onkyo Audio... • Answered on Jul 25, 2023
Onkyo DTR7 Receiver Logo
Popular Tags
7 questions posted
Popular Products
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Audio Players & Recorders
Most Popular Question
sound suddenly disappeared dtr7 both b
  • Audio Players & Recorders
