20 Most Recent Onkyo TX-DS939 Receiver Questions & Answers
did you solve the problem ? i have the same thing
Onkyo TX-DS939... | Answered on Oct 02, 2015
Yes.
There are several other methods for your surround sound channels to operate without your optical connection.
Onkyo TX-DS939... | Answered on Jan 01, 2011
Sounds like you've blown the audio amplifier, you'll have to get it repaired by a service tech.
Onkyo TX-DS939... | Answered on Oct 20, 2010
What you are getting is excessive phase shift at the lower-frequency edge of the audio pass band, causing oscillation. This is almost always due to aging capacitors or preamp
.Replacing preamp or capacitors will surely solve the problem.
check the coupling capacitors for the speaker outputs. It probably has quasi-complimentary transistor configuration in the amp section. If they loose capacitance the circuit can become unstable.
check the leads on the square transistors.If they are bolted down the leads sometimes break where they are bent.
post a comment for further assistance.
thank you for using fixya have a nice day:-)
Onkyo TX-DS939... | Answered on Aug 28, 2010
Im not saying that this will solve your issue since there is nothing listed anywhere on the manual or any website that help with this. But I had the same error code a few month back. I had 3 issues.
1. Speaker wires not connected fully. ( Even though it worked ok for over a year)
2. Power failure ( Had to replace the power supply)
3. Internal Control board failure. ( Had to replace the control board)
Now I do know that you can also contact the manufacture about this issue also. So that may be a step in the right direction. The last thing you can try is to unplug the unit for 15 minutes then plug it back in. Resets the system.
Onkyo TX-DS939... | Answered on Jan 06, 2010
disconnect the speakers and see if it does the same thing.
if it does not shut down,check that the speaker wires are not touching on the back of the speakers.
many times,people run over the wires with a vacuum or similar and a short results,or bump the speaker.most people have the leads way too long,and even if one strand touches,it will shut down the amp.
if it still shutting off,there is an internal problem.
the best place to go with an onkyo is an authorized depot.
they are tricky to work on.
i did onkyo warranty for 7 years.
Onkyo TX-DS939... | Answered on Sep 06, 2009
Hi...
If you've had it "fixed" 3 times and the problem comes back either you have the wrong impedance (ohms) speakers connected or the power supply in the unit is the actual problem.
Happy new years,
Scott
Onkyo TX-DS939... | Answered on Jan 01, 2009
+22v line is missing. Check for 22v at R9207, not present check R9201,2 0.22ohm, R9203-6 1 ohm. Check also Q9201 12v reg ic, it supplies the led in the volume ctl. While your in there, solder up any cracked solder joints, bad connections.
Onkyo TX-DS939 Receiver Logo
35 questions posted
Popular Products
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Audio Players & Recorders
Most Popular Question
turn power amp goes protect mode
  • Audio Players & Recorders
