20 Most Recent Onkyo TX-SR700 Receiver Questions & Answers
Please provide instructions for how to play music from I phone/IPOD using analog. I plugged in the devise into the Video 4 area in lower right hand corner.
Hi Kathy, the easiest way to do this on your txsr700 would be for you to purchase Y connector which will have RCA connections on one end and a headphone jack on the other end. Connect the RCA cables to any open RCA connection other than the Phono input and then connect the headphone jack to the iPod. Please be sure that the volume is turned up a bit on the iPod. If you should require further assistance please feel free to contact our Product Support Team at 800-229-1687, Thanks, JT
8/26/2015 6:14:59 PM • Onkyo TX-SR700... • Answered on Aug 26, 2015
Volume is stuck on max.
Do you have the manual and have you thumbed through it?
Register and download the manual for free at
retrevo.com http://www.retrevo.com/support/Onkyo-TX-SR700-Receivers-manual/id/365ag223/t/2/ It always puzzles me when someone fixates on the remote when a unit has front-panel controls. You say "The pot does not seem to be the issue." Does that mean it is ineffective or is it faultless in your estimation? The HUGE volume knob (#16 on page 8) controls volume (in the main zone), too. If your complaint involves speakers on Zone 2, the up/down arrows at #22 on page 8 apply.
3/4/2011 11:03:44 AM • Onkyo TX-SR700... • Answered on Mar 04, 2011
Can I connect my Denon
It looks like there are digital inputs on the left side of the ax10 (looking from the back )that you could plug right into with RCA cable. Use zone three on the AVR and remember these are pre-amped connections so little gain will be needed. Also only audio no video can be sent. good luck Joe
2/19/2011 4:53:32 PM • Onkyo TX-SR700... • Answered on Feb 19, 2011
Can I connect my Onkyo TX-SR700 Receiver's Pre Out
yes. in order to do so, all analog input connections must be utilized by each device connected to the oynko
5/31/2010 3:15:20 PM • Onkyo TX-SR700... • Answered on May 31, 2010
My receiver sat for five years, now it states "Protect"
Ok protect means there was a problem on the circuit, I am not there to see but please check for any bad capcitors,rails,amps ect ect if you do not know how to check this your going to need to check it into a repair shop for a eval.
Thanks I hope this helps please do rate the solution with the 4 thumbs above. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
2/13/2010 7:16:54 PM • Onkyo TX-SR700... • Answered on Feb 13, 2010
2answers
Onkyo receiver memory power backup not working
How change battery and the battery model
2/4/2010 7:35:55 AM • Onkyo TX-SR700... • Answered on Feb 04, 2010
My Onkyo Tx-Sr700 sound is not working. I have
make sure you have audio cables connected from your cable providers audio out to your receivers audio in on video 1 press the video 1 button you should hear the sound.
10/17/2009 3:17:55 AM • Onkyo TX-SR700... • Answered on Oct 17, 2009
Onkyo Zone 2 problem
The zone 2 will only play analog sources - so  you must hook up the output from the tv/cable/dss on it's analog (RCA Jacks) into an input on the Onkyo.  You might also have to enable this output from you tv/cable/dss.
11/20/2008 10:47:29 PM • Onkyo TX-SR700... • Answered on Nov 20, 2008
0-83 error on onkyo tx nr 555
The 0-83 error indicates a problem with the firmware update. Try resetting the receiver's BIOS by following these steps2: Unplug all cables Un-Power the receiver Power the receiver Before the receiver gets into the "Enter for updating" message, press Tone + CBL/SAT + ON/STANDBY. This will show you either the volume numbers or get you into settings of the receiver's speaker configuration. Press CBL/SAT + ON/STANDBY. This will clear the BIOS and show a "Clear" message on the display. Wait until you hear a couple of clicking sounds for the receiver to turn on and off the power. TX-NR555 Owner's Manual - Onkyo Product Support (onkyousa.com)
2/26/2024 3:51:06 AM • Onkyo Audio... • Answered on Feb 26, 2024
2answers
Onkyo nr 555 stuck on recovery:NET
Hello Did you update the AVR over the internet? If so the device wont work anymore. You need to service the device in a nearest Onkyo service department. Regards
2/24/2024 6:24:24 PM • Onkyo Audio... • Answered on Feb 24, 2024
3answers
Onkyo skw 591 subwoofer...blue light is on and no sound? any thoughts?
Hello, To test the subwoofer when the blue light is on if you apply your thumb to the end of the subwoofer cable (the end that you would plug into the receiver) there should be feedback from the sub. If there is no feedback then the sub is not working correctly. Thanks, FJD
1/2/2024 2:06:41 AM • Onkyo Audio... • Answered on Jan 02, 2024
Part number of battery on onkyo digital board for TX DS-797
Here is service manual for your help. See the pat reference on IO Board and compare it with service manual. ONKYO TX-DS797 SERVICE MANUAL Pdf Download ' ManualsLib
12/31/2023 9:27:34 AM • Onkyo Audio... • Answered on Dec 31, 2023
Onkyo HT-R758 AV Receiver.
There are several causes of this problem. My be mute is ON, may be fuse is blown etc etc. However refer to page 62 of manual, it will help. HT-S6500_English_2022-11-02-204020_ivkn.pdf (onkyo-av.com)
12/11/2023 2:09:15 PM • Onkyo Audio... • Answered on Dec 11, 2023
Onkyo powered subwoofer SKW-791
Oknkyo SKW-791 has build in amplifier. So it can be connected through Line Out Connector of sansui amplifier. If speakers out is connected with subwoofer, the circuit board in subwoofer will be blown.
12/11/2023 2:03:09 PM • Onkyo Audio... • Answered on Dec 11, 2023
How do I hook my onkyo SKW-791powered subwoofer to my onkyo av receiver HT-R758
You need a RCA sub-woofer cable (analog mono) to connect between the receiver's sub-woofer Pre Out and the sub-woofer. This cable has a single RCA plug at each end of the cable. The cable is somewhat thicker than some audio RCA cables. You can use any RCA cable temporarily. The manual for the HT-R758 is available from Onkyo here: https://onkyousa.com/ht-r758 . The current link to the manual is https://assets.onkyo-av.com/product-manuals/HT-S6500_English_2022-11-02-204020_ivkn.pdf?v=1667421620 . See page EN-13 (page 13 of the PDF) for connecting to the subwoofer. The original package came with a 10' RCA sub-woofer cable, see page EN-1 (page 81 of the PDF) for the speaker list. I hope this helps. Cindy Wells
12/10/2023 12:09:43 AM • Onkyo Audio... • Answered on Dec 10, 2023
Onkyo TX-SR700 Receiver Logo
17 questions posted
Popular Products
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Audio Players & Recorders
Most Popular Question
connect onkyo tx sr700 receivers pre out
  • Audio Players & Recorders
