Samsung Galaxy S4: How to open back battery cover: 1) Flip the phone over so you see the back cover.. 2) Locate the notch on the side of the phone with your fingernail and pull the cover easily up to unlatch that area and all areas around the phone.. With one hard pull you can easily take off the whole cover.. don't be shy, your Samsung phone is sturdy enough to handle it. All the blue arrows in the below image shows where the cover clicks into the inside of the phone to keep it closed. 3.) when you need to put the cover back on the phone.. place the cover over the back part of the phone, noting that the camera hole in the cover goes at the top.. Then grip your left hand on the left side of the phone and your right hand on the right side of the phone.. apply pressure to each side to click the latches to the phone locking it in place. Afterwards, run your fingers along the back sides of the phone to see if there are any bulges (a latch may not have clicked in place). Either apply pressure there to click it into place or you may have to take the cover off again and try again. It's very simple and easy once you get the hang of it. How to Open Samsung Galaxy S4 Back Cover Insert Battery SIM Replace Back... .Bending the back cover will not damage it because it is plastic.. unless you bend it to crease it. Below is Samsung's durability test.https://www.youtube.com/watch?v=UrhCz6PnT78(you may need to copy and paste this link to make it work).
Hi
Samsung phones and probably most other phones store all networks detected throughout their lives unless you select them and tell them to "Forget" particular connections. This applies even when the network settings don't match the settings of the network you are trying to connect to.
I would suggest that you "Forget" the connection you are trying to connect to. After a while the phone will detect the network and if you tap this network it will ask you for a password. Enter this and it should connect it the network without trouble.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Battery may not be charged enough to run the phone. Keep the phone off and connect it to a charger to fully charge the battery or use an external battery charger.
Be sure the The micro usb connector is fully seated and that the battery is actually charging. A loose connection may appear to start the charging process, but if its loose, it may not be continuing to charge. Check the % progress. If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
If your phone was stolen, your best bet is to go to your wireless carrier and let them know, they will block the imei so that it can't be use anymore. The S4 comes with Android Device Manager, which you can control your S4 from a computer, but this will only work if you activated the phone with your google account, try going to accounts.google.com and log in with your google account. Best of luck.
To hard reset your Samsung ST1000 camera, follow these steps:
Reset Settings via Camera Menu:
Open the camera app.
Tap on the Settings icon (usually represented by a gear).
Scroll down and select Reset settings.
Confirm the reset by choosing Yes when prompted.
Physical Reset (if needed):
Locate the reset button on your camera (refer to the camera's manual for its exact location).
Press and hold the button for at least 10 seconds until the camera restarts
This seems to be a known issue where the Samsung Music app starts randomly1. Here are a few steps you can try to resolve this issue:
Check if an app you downloaded is causing the problem: Start the phone in Safe Mode. If the problem does not occur in this mode, then you need to find out what app this is and uninstall it.
Wipe the cache partition of the phone from the recovery mode: This can often resolve issues with apps misbehaving.
Perform a factory reset: Please remember to backup your phone data before doing this. Once the reset is complete, do not install any apps in your phone yet. Try to check first if the issue still occurs.
Check Power Saving Mode: The power saving mode could interfere and block your music-streaming app if turned on.
If none of these steps work, it might be a good idea to contact Samsung's customer service for further assistance.
SIM Card Tray Issue: The SIM card tray might be damaged or not properly aligned. Ensure that you are inserting the SIM card into the tray correctly and that the tray is properly seated in the device.
Incompatible SIM Card: The SIM card you're trying to use might not be compatible with the Samsung Tab 10.1. Ensure that you're using a SIM card that is supported by your device and is of the correct size (micro-SIM or nano-SIM).
Dirty or Faulty SIM Card Contacts: Dust, dirt, or debris on the SIM card or SIM card tray contacts can prevent proper connectivity and cause the SIM card to eject. Clean the SIM card and the tray contacts with a soft cloth and reinsert the SIM card.
SIM Card Slot Issue: There could be an issue with the SIM card slot itself. Inspect the slot for any physical damage or debris that may be causing the SIM card to eject. If you notice any damage, you may need to have the device repaired by a professional.
Software Issue: Sometimes, software glitches or conflicts can cause the SIM card to eject unexpectedly. Try restarting your Samsung Tab 10.1 or performing a factory reset to see if the issue persists.
If none of the above steps resolve the issue and the SIM card continues to eject, it may indicate a hardware problem with your device. In this case, you may need to contact Samsung customer support or visit a certified repair center for further assistance.
