20 Most Recent 2003 Chevy Astro - Passenger van, with factory roof rails - Base Rack System Questions & Answers
They must have them if it has an engine with pollution gear on it.
2003 Chevy Astro... | Answered on Nov 17, 2015
Replace thermostat in the motor ,make sure the hoses to the convertor are not blocked ,pour hot water on the fuel pipe and convertor to thaw out.
The module is part of the door latch itself. Replace the door latch assembly to fix problem.
2003 Chevy Astro... | Answered on Feb 20, 2015
It's not the switch try the resistor
2003 Chevy Astro... | Answered on Mar 06, 2014
This could be a few things but always start with the basics (and cheapest). Check the tires for broken belts. If the tires are worn smooth, don't run your hand on them, you could get a sliver of steel belt in them (it hurts, trust me). If they aren't worn that much, run your hand over the tread and see if you feel any bumps.
If the tires seem ok, crawl under and grab the drive shaft. Make sure the van is parked on the level with no load on it (no weight on the parking pin...). If you can move it from side to side or there is play in it, it's probably the carrier bearing. It's not that expensive to fix by a mechanic ($150 roughly) or you could do it yourself with a basic socket set.
2003 Chevy Astro... | Answered on Dec 10, 2013
You can go to your local Chevy dealer- talk to the parts counterman and ask him to print out a copy of the fuse box diagram or get a service repair manual online or at an auto parts store.
http://www.chiltondiy.com/
http://www.haynes.com/onlinerepairmanuals/
2003 Chevy Astro... | Answered on Dec 08, 2013
do you have to add coolant and is there a rear heater core in rear ??
Thule Vehicle... | Answered on Feb 09, 2015
Are the bolts seized or is there a release pin?
Thule Vehicle... | Answered on Sep 02, 2014
Are these factory acessories or another name brand?
Ronald, sometimes thing just don't happen like the book says so in times such as this I have been known to bring out the mig welder and fabricate a mount that will work and the modifications shouldn't be noticed from the topside of the vehicle. Be sure to use suitable materials 3/16th inch wall mild steel and that proper prep work and proper welding procedures are observed and you will have the box serve you well for years to come.
Thule Vehicle... | Answered on Jan 01, 2014
Demi,
The Loadcarrier 1061 is an older model and onl;ine data is hard to find, if there at all. To know more about the feet and fit kit, I recommend you call Thule Customer Support line at 800-238-2388 (Monday - Friday 8:30AM - 5:30PM EST).
Hope this helps. - RedRanger
Thule Vehicle... | Answered on Nov 16, 2013
Repost under RV for an answer
Thule Vehicle... | Answered on Jul 25, 2013
should be on the tail of tranny left side
Vehicle Parts &... | Answered Yesterday
You need to register with snooper to download the updates(even if previous owner has done so) or else you can ask him his user id and password
Vehicle Parts &... | Answered 2 days ago
You can use this for most of it. Most remote starts/keyless entry/alarm do the same things. Most are even colored the same way.
https://www.manualslib.com/manual/460639/Directed-Electronics-Autocommand-25523t.html
Vehicle Parts &... | Answered on Jul 11, 2019
Why you need a wrap? The new ones are wrapped mainly cos people don't like the company color and they want their ride to be unique. I believe it's the same for you. Vehicle wraps are better option; cheaper compared to repainting; easy to remove when you think you changing it.
Vehicle Parts &... | Answered on Jul 09, 2019
I would check your crankshaft sensor , also your fuel filter to make sure it is clear
Vehicle Parts &... | Answered on Jul 05, 2019
2003 Chevy Astro - Passenger van, with factory roof rails - Base Rack System Logo
6 questions posted
Top Thule Vehicle Parts & Accessories Experts
randymanfive
Marvin
Marvin
Serge Joncas
Are you a Thule Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Thule Vehicle Parts & Accessories
Most Popular Question
frozen gas lines in 2003 chevy astro van
  • Vehicle Parts & Accessories
