20 Most Recent
Netopia 4622-XL Router Questions & Answers
How to port forward on Netopia 3347WE
1. Click the Expert Mode link near the left of the page.
(it is not listed in the manual)
2.Click the Yes, enter expert mode button near the centre of the page.
3. The menu on the left should change. In this new menu, click Configure.
4. You should now see a new menu. In this new menu, click NAT.
5. Click the Define Custom Service button near the center of the page.
6.Put a dot into the Port Forwarding: Range of Ports radio button. 7. Click the Next button. Then set up the ports you want to forward. One Example s here
O
Port Forwarding the Netopia 3347W Router for Xbox One
3/15/2015 8:16:11 PM •
Netopia...
Answered
on Mar 15, 2015
Reset the password on my Netopia 3347-02-1006 router
Hi You can fix this problem by entering 192.168.1.1 or your routers ip.then you can accsess your routers software and in the WLAN section you can change the password or reset. try looking under every section until you find the correct area which you can do things to the WLAN setting. Hope this worked :)
12/26/2014 11:53:14 PM •
Netopia...
Answered
on Dec 26, 2014
Reserve ip address
It all depends on the brand of your router, but mainly is to jump into the GUI with your admin password, look for DHCP options, static DHCP and save the MAC Address of the host with the desired IP.
7/1/2014 9:22:50 PM •
Netopia...
Answered
on Jul 01, 2014
Need password
"Try http://www.fixya.com/support/r11153882-general_routers_reseting"
5/29/2014 12:13:10 PM •
Netopia...
Answered
on May 29, 2014
Conect webcams on a local network to a website
I presume that you mean "from a web site" that the web site is hosted somewhere out on the greater internet.... The problem that you are encountering is probably related to NAT (Network address translation). The "In" side of a router, is typically a "private network" there are pre-assigned number groups for these - a common one is in the 192.168.x.x range. Problem is that the "outside" of your Netopia router will be dependent on your ISP< and unless you are paying them extra for a static IP address, is likely to change every time you reboot - or sometimes they bump them every 24 hours. So, first thing is get a dynamic DNS Entry - www.dyndns.org is one supplier - I think you can get one address for free from them, pay for more.. YOu set up something like CMVideo.dynsdns.org on their site, and set up dyndns support in the netopia router... Then you want to open the specific port on your router, to go to the internal IP Address of your camera. (YOu mention Multiple Cameras - depends on the Camera you may have to go for multiple dyndns (one for each...) ).I am a little confused/concerned about the second router "tier" - if you have the Belkin configure as an Access Point only, all good, if you are trying to run it as a router behind a router, it will probably never work - double nat-ting" is a no no with most consumer Routers. Simple solution is to tap from Netopia lan side to Belkin Lan side (rather than Belkin Wan Side)
11/14/2013 9:38:37 PM •
Netopia...
Answered
on Nov 14, 2013
