20 Most Recent
Duracell Powerpack 300 300 Watts Vehicle Jumpstart Detachable LED Flashlight Builtin Air Compr Questions & Answers
I have replaced the batteries in 2 duracell 350 flashlights but I can't make them turn on.
the bulbs could be bad, the batteries could be bad, you could have replaced with incompatible batteries or have the wrong orientation. did you realign the compartment to make contact ? often the spot where the batteries go have a wire or metal that connects to another wire or metal when you replace the battery compartment- maybe that metal or wire is not aligned correctly or touching like it should. This was not a question but more of a generalized problem that could have so many solutions. Im not sure more information would have.
good luck
https://www.6ya.com/mrmmike
3/2/2019 9:18:17 PM •
Duracell...
Answered
on Mar 02, 2019
Where can I find replacement parts for my rechargeable lantern?
It's great that you're looking to revive your rechargeable lantern! Here are some steps you can take to find replacement parts and ensure your lantern is in working condition:
- Check with the Manufacturer: Start by contacting the manufacturer of your rechargeable lantern. They may offer replacement parts for your specific model, including the light tubes. You can inquire about replacement batteries as well.
- Search Online Retailers: Look for online retailers specializing in selling replacement parts for lanterns and flashlights. Websites like Amazon, eBay, or specialized outdoor equipment stores may carry the replacement light tubes you need. Make sure to check if they ship to Canada.
- Visit Local Hardware or Outdoor Stores: Explore hardware stores, camping supply stores, or outdoor equipment retailers in your area. They may have replacement light tubes or similar products that are compatible with your lantern.
- Consider Universal Light Tubes: If you cannot find the exact replacement light tubes for your lantern, consider purchasing universal light tubes that fit the size and specifications of your lantern's sockets. Be sure to measure the dimensions of the sockets and compare them with the specifications of the replacement tubes.
- Test the Battery: Before purchasing replacement parts, it's a good idea to test the battery to see if it still holds a charge. If you have a compatible charger, you can try charging the battery and observing its performance. If the battery no longer holds a charge or shows signs of leakage, you'll need to replace it.
- Inspect for Damage: Since the lantern has been in storage for several years, carefully inspect it for any signs of damage or wear, especially around the battery compartment and electrical components. If you notice any corrosion or damage, it's best to address those issues before using the lantern.
By following these steps, you should be able to find replacement parts for your rechargeable lantern and get it back into working condition. If you encounter any difficulties, don't hesitate to contact customer support or seek assistance from a local retailer.
4/16/2024 9:58:57 PM •
Camping,...
Answered
on Apr 16, 2024
