20 Most Recent
Dorcy International p6V Floating Luminator Lantern with 6V HD Battery Questions & Answers
How do you install 6V battery into Dorcy luminator
I was just having the same problem - I didn't realize that I had to take the black caps off the two springs at one end of the battery! Once I pulled those off, and put the battery in with the springs facing up, I was able to screw the top of the flashlight back on, and it worked. I hope this helps.
2/8/2013 4:37:40 PM •
Dorcy...
Answered
on Feb 08, 2013
My mobile screen is blank
Depending on phone you just may need to do a hard reset. Example would be for droid razor HD since you did not list make or model. Hold all three buttons (power, volume up, and volume down) on side until screen Goes blank and the you should see phone start right up. If not you may have dropped one too many times and have bad/broken connections/contacts.
11/17/2014 3:18:02 PM •
Dorcy...
Answered
on Nov 17, 2014
Do you need special hiking shoes for going on long walks?
Whether or not to buy hiking shoes really depends on what kind of walking you plan to do and how often.Hiking boots are helpful for rougher terrain and for gripping. If you plan to mostly walk on flat ground, you can consider getting good walking shoes instead.
1/25/2024 4:10:25 AM •
Camping,...
Answered
on Jan 25, 2024
What is camp furniture?
Camp furniture is items like tables and chair that are madeout of a durable material, are light and can be folded up and packed.
1/10/2024 2:37:49 PM •
Camping,...
Answered
on Jan 10, 2024
How do you take apart a bushneell 600 lumens flashlight
Taking apart a flashlight, including a Bushnell 600 Lumens flashlight, may not be recommended, as it can void the warranty and potentially damage the device. However, if you have a specific need to disassemble it, here are some general steps to follow:
1. Remove the batteries: Ensure the flashlight is turned off, and remove any batteries to prevent any accidental activation or electrical shock.
2. Look for screws or openings: Most flashlights have screws or openings around the head or tail cap that allow access to the internal components.
3. Unscrew components: Use the appropriate screwdriver or tool to remove any visible screws holding the flashlight together. If there are no screws, try gently twisting and separating the parts.
4. Be cautious with wires: If your flashlight has internal wires and circuitry, be extremely careful not to damage them while disassembling the flashlight.
5. Document your steps: Take photos or notes as you disassemble the flashlight to help you remember
10/24/2023 4:55:23 PM •
Camping,...
Answered
on Oct 24, 2023
COASTHP7 flashlight bulb replacement ?
Try contacting COAST directly. I think they give a Lifetime Warranty on their flashlights. Ask for the repairs department. You never know, they might do it for you under the warranty. There's no harm in asking them.
10/10/2023 9:20:36 PM •
Camping,...
Answered
on Oct 10, 2023
