20 Most Recent
Energizer Eveready Utility Lantern Uses 6V Lantern Battery Questions & Answers
I have bought a new
The bezel (the circular portion on the front of the flashlight that holds the bulb and lens) will unscrew. The old battery should slide right out.
Hope this helps.
6/29/2019 2:28:37 PM •
Energizer...
Answered
on Jun 29, 2019
Replacing a 6 volt battery
Check that the contacts where the springs on the battery make contact in the light to see if they are corroded. If so scrape or sand them off.
12/1/2016 3:44:30 AM •
Energizer...
Answered
on Dec 01, 2016
How to fix the switch on eveready lantern flashlight
The switch in the lantern is a press fit switch so you will destroy it when you remove it. Remove the lense and retainer ring. Remove the battery. With a pair of pliers, preferably channel lock water pump pliers crush the switch into small piece and discard. Trail Tech makes the exact water resistant switch model 040-ls-b and you can get it at Amazon or on eBay . The switch runs around $6.25 + $4.00 shipping
12/1/2016 3:39:41 AM •
Energizer...
Answered
on Dec 01, 2016
How do I change the
If it is the yellow floating lantern you have to remove the black plastic stub on the underside of the reflector using needlenose pliers to wiggle and slightly pull until it releases and the bulb will come out.
12/1/2016 3:31:50 AM •
Energizer...
Answered
on Dec 01, 2016
How to connect a spring pole 6v battery
Inside the case of the light, there will be 1 wire with a tapered notched connector. Take the connector with the low end of the taper and push it into the negative (-) spring (in between the coils ) of the battery. The spring will wedge the connector it one of the notches and will hold it securely. Reattach the lense carefully seating the end of the bulb onto the positive (+) spring of the battery.
11/21/2016 6:22:04 AM •
Energizer...
Answered
on Nov 21, 2016
How to test a flashlight bulb
To test a flashlight bulb you use an Ohm meter which will detect a broken filament or an open circuit within the bulb. If the bulb is bad it will read "OL" if it's good it will read "00.0"
11/21/2016 6:12:16 AM •
Energizer...
Answered
on Nov 21, 2016
How do I get to the bulb?
Unscrew the head assembly. In the back of the assembly is a small plastic nut. Unscrew this and the bulb should fall out into your hand.
11/1/2014 3:30:21 PM •
Energizer...
Answered
on Nov 01, 2014
