20 Most Recent
Bugaboo 'Cameleon' Stroller Questions & Answers
One wheel doesnt seem to brake when i put the
This is a common problem with the bugaboo's The brakes use a toothed brake shoe to fit in to a toothed inner rim, What happens is one shoe seems to alway fit into the toothed rim but while the other side always hits the top of the teeth causing the shoes and connecting rod to twist. Eventually you get the problem you describe. The brakes shoes are interconnected by an aluminum rod. The shoes have two splines that fit into slots in the rod and a phillips screw to lock them in. First try taking the back wheels off and getting a strong man to hold the shoe that doest lock while pulling the one that does back in to alignment. This quite often works. If the twist is to much I remove one shoe cut off the splines turn the shoe to align with the other shoe then drill a new hole for the locking screw.
10/11/2014 9:43:09 PM •
Bugaboo...
Answered
on Oct 11, 2014
How to fix bugaboo lever
Speak to someone at Buggy Pitstop. They fix all Bugaboo problems.www.buggypitstop.co.uk
8/6/2013 3:25:40 PM •
Bugaboo...
Answered
on Aug 06, 2013
Im trying to fit a new break cable to my bugaboo cameleon
They are a tricky thing to fit. First fit top cable this involves taking the two screws out and having the lever, spring and lock button all pop out. Cable is easy to fit now but a bit fiddly putting back together. Make sure cable stays in its groove around the lever base. Now fit bottom end of cable to the brake shoe. It is easier to do if you take the bolt holding the spring off first. You'll see the slot in the shoe for the cable you have to fit the cable almost 180 degrees from it's usual position then turn back to usual position. Now fit spring back , pull cable adjuster up past the bracket that holds and then slip cable though slot. Finally clip rest of cable to its frame clips than adjust.
11/29/2011 8:11:21 AM •
Bugaboo...
Answered
on Nov 29, 2011
The shoulder strap adjustors (the
No that should not happen. Bugaboo have very good customer service while in the two year warranty period that all turns to custard the day after it expires, So contact them now!
9/1/2011 6:14:33 PM •
Bugaboo...
Answered
on Sep 01, 2011
