20 Most Recent Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008 Brand Booster Car Seat Questions & Answers
Cannot adjust position
Hi Grip the carseat on the underside of the front lip, push the button in and lift the front to recline / push down to put in a more upright position. b7dfca4d-ad79-4177-a4ff-232802ebd77a.jpg
9/14/2014 7:55:30 PM • Maxi-Cosi Maxi... • Answered on Sep 14, 2014
2answers
Pulled tensioner on maxi cosi tobi now i cant
Just did it. It took two of us, but only a couple of minutes and no tools (except a table knife) once we'd worked out what the problem was. The reason the strap doesn't thread easily through the slot is that there is a sprung two-part mechanism that needs to be held open. One person threads the strap through while the other keeps the mechanism open.
Person 1:
1) Find the slot under the chair that the strap goes into - turn the seat upside down; it's a thin gap you can feel with your fingertip when you run your finger along the narrow back of the metal strip under the front of the seat (not the base).
2) Remove the metal rod that attaches the grey reclining lever. The rod is about 20 cm long and can be pushed out without tools. Removing this rod seems to make it easier to open the buckle mechanism. When replacing the rod later, you just have to line it up carefully with holes (we used a torch to help us see them)
3) Make sure the strap passes under the metal rod at the bottom of the seat back (you can see how here in a small photo here: http://www.englishforum.ch/attachments/sale-wanted/37565d1327058634-sale-maxi-cosi-tobi-car-seat-9mths-3-yrs-zh-maxi_cosi_tobu_small.jpg)
Person 2
4) Push back buckle as far as it will go (it goes back past vertical easily, then needs another firmer push,
5) Hold the buckle in this backwards position.
6) Insert a table knife (rounded and blunt, not sharp) into the space under the buckle and push back the sprung, hinged plastic part that the knife touches at the back.
7) Person 1 then threads the strap back through the slot, pushing until then end comes out.
8) Tie a knot in the end of the strap so you don't accidentally pull it through again!
9) Replace the metal rod in the reclining mechanism.
10) Done!
5/19/2012 8:13:07 PM • Maxi-Cosi Maxi... • Answered on May 19, 2012
Is it possible to buy new covers and straps for
Replacement fabrics can be ordered via your local Maxi Cosi retailer or direct from the customer services department on 01284 413 141 Mon-Fri 8.30-4.30. RRP is 60GBP and if purchased direct there is 3.99GBP p+p
12/13/2011 11:25:57 AM • Maxi-Cosi Maxi... • Answered on Dec 13, 2011
Hi, i cannot get
Hi Lorna - Most commonly this issue is caused by dirt/debris getting caught in the tensioning strap of the harness and gradually pulled into the mechanism of the carseat over time. First recommendation is to remove carseat from the car and remove cover (do not remove harness system from seat) give the carseat fabric and the seat itself a clean and see whether this improves the recline situation. If not, please contact your customer services department - if you're in the UK this is 01284 413 141 Mon-Fri 8.30-4.30
11/29/2011 11:11:47 AM • Maxi-Cosi Maxi... • Answered on Nov 29, 2011
I can not lower the car seat. It is blocked. What
Hi - For assistance in Croatia, please contact:00385 1 2406-500
11/29/2011 11:08:02 AM • Maxi-Cosi Maxi... • Answered on Nov 29, 2011
Seatbelt straps won't fix and
Good AfternoonHow old is your carseat? If it is under 2 years old please return to your retailer with proof of purchase and ask them to make arrangements for it to be sent in under warranty terms and conditions.If it is over 2 years old or you do not have proof of purchase please contact our customer service department on 01284 413 141 Mon-Fri 8.30-4.30.
11/10/2011 3:02:36 PM • Maxi-Cosi Maxi... • Answered on Nov 10, 2011
How to install seat in car
Good AfternoonPlease take the vehicle to an authorised retailer and ask for a carseat fitter trained member of staff to provide a physical fitting prior to purchase to confirm suitability of this seat in your vehicle. They will at the time provide demonstration on how to correctly fit.
11/10/2011 2:50:49 PM • Maxi-Cosi Maxi... • Answered on Nov 10, 2011
I wash the cover but i accidentaly fulled the belt
Good AfternoonFor safety reasons, the carseat needs to come back for our engineers to provide this repair work. Please call the customer service department on 01284 413 141 Mon-Fri 8.30-4.30 to talk to an advisor.
11/10/2011 2:39:22 PM • Maxi-Cosi Maxi... • Answered on Nov 10, 2011
Maxi cosi tobi strap has jammed
It's not possible to loosen the belts of your Tobi?In this case you may need a repair of the quick-adjuster (the part where the buckle is attached to) or it may be appropriate to exchange the quick-adjuster.Because this part is directly affecting the safety of the seat I would advise you not to try to repair it yourself; please visit a Maxi Cosi dealer to have it serviced.I hope this helps.Erwin de Raadwww.babycare.nl
9/29/2011 6:10:54 PM • Maxi-Cosi Maxi... • Answered on Sep 29, 2011
I need to clean a
HiIt isn't recommended that you take apart the plastic shell of the carseat. You can remove the fabric from the carseat to wash it and then clean the shell with warm soapy water but it is not advisable to remove the harness or to take apart the factory seal of the shell.Have a look at www.maxi-cosi.com and select the country you're in, then choose the Tobi carseat and select the instructions to view directions on how to remove the fabric.
9/29/2011 2:54:40 PM • Maxi-Cosi Maxi... • Answered on Sep 29, 2011
Need instructions for adjusting straps
Good Afternoon
Please visit www.maxi-cosi.com and select the country you're in, then select the Tobi carseat and download a replacement user manual which will have information on how to adjust straps and remove fabric.
7/21/2011 3:17:01 PM • Maxi-Cosi Maxi... • Answered on Jul 21, 2011
How to alter the straps
how to adjust straps in maxi cosi tobi
7/13/2011 8:54:47 AM • Maxi-Cosi Maxi... • Answered on Jul 13, 2011
How do you re-thread the
Good Afternoon
Due to the safety implications of the harness being incorrectly re-fitted, in this instance the carseat needs to be sent to our engineers for full inspection & replacement of the harness. Following replacement of the harness, full safety checks will be carried out prior to the unit being dispatched back to you.
Are you a UK customer? If you are, please contact our customer service department on 01284 413 141 Mon-Fri 8.30-4.30. Standard charge will be £60 and this will include courier delivery service of the carseat back to your address, in addition you would need to make arrangements and cover costs for courier delivery of the product into our engineers.
If you're not a UK customer please visit www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab to get in touch with the customer service department in your area.
5/26/2011 12:20:27 PM • Maxi-Cosi Maxi... • Answered on May 26, 2011
How can i make the headress go upto make the
Good Evening
Take hold of the headrest and lean it forward (toward the front of the carseat) then you can slide it up and down to wherever the harness needs to be for the best fit for your child.
The shoulder straps should be no more than 1 inch above or below the childs shoulders when correctly adjusted.
1/20/2011 7:00:43 PM • Maxi-Cosi Maxi... • Answered on Jan 20, 2011
Is it possible to purchase
Good Evening
You can order the replacement polystyrene inserts via most authorised Maxi Cosi retailers or direct with our customer service department on 01284 413141 (Mon - Fri, 8:30 am to 4:30 pm)
1/20/2011 6:56:51 PM • Maxi-Cosi Maxi... • Answered on Jan 20, 2011
Repair broken wire on Maxi-Cosi 2wayfix base.
Hello In some countries Maxi-Cosi do have service centres where inspection & repair is possible. You should contact your local Maxi-Cosi office (Facebook or via Maxi-Cosi website, "Contact Us" option) They will be able to advise you.
11/15/2019 8:47:48 PM • Maxi-Cosi Baby... • Answered on Nov 15, 2019
The car seat I have
Hi Maxi-Cosi do not produce the adapters for the carseat to be used with Mamas & Papas chassis. Adapters would be designed, tested, approved and sold from Mamas & Papas. If the adapters do not fit the carseat they need to investigate this for you. The CabrioFix carseat is only one model and regardless of date of manufacture all Maxi-Cosi adapters for CabrioFix are the same. (For using Maxi-Cosi carseat on Maxi-Cosi pushchair chassis)
2/6/2019 4:34:53 PM • Maxi-Cosi Baby... • Answered on Feb 06, 2019
How do I reconnect t the cable on the maxi-cosi isa base apparently it's a common fault with this product
Hi Rita The base will need to come in for our engineers to provide inspection and repair required. Please contact the customer care team to book in. 25321888-i0wfs0fmvr0ltuvhwxoio5ko-5-0.jpg
12/15/2014 12:18:59 PM • Maxi-Cosi Baby... • Answered on Dec 15, 2014
The spring has come apart on the maxi-cosi family fix base
The unit will need inspection / repair. If you're in the UK and the product is under 2 years old, please contact your retailer with your proof of purchase and they can arrange for it to be sent to our engineers for inspection / repair work required under warranty. If you're in the UK and the product is over 2 years old or you no longer have proof of purchase please contact the customer care team on 01284 413 141 Mon-Thur 08:30-17:30 / Fri 08:30-16:30 (Excluding Bank Holidays) to discuss booking it in for chargeable inspection / repair work required. If you're outside the UK please visit www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab on the right side for your enquiry to be sent through to the customer care team in your country.
9/14/2014 8:38:15 PM • Maxi-Cosi Baby... • Answered on Sep 14, 2014
Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008 Brand Booster Car Seat Logo
17 questions posted
Top Maxi-Cosi Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
View Most Popular
Maxi-Cosi Baby Gear
  • Maxi-Cosi Baby Gear
Most Popular Question
pulled tensioner maxi cosi tobi now
  • Baby Gear
