20 Most Recent Peg Perego John Deere Loader Pedal Tractor Questions & Answers
I bought one of these at a garage sale and can not
under the hood
5/14/2012 8:15:09 PM • Peg Perego John... • Answered on May 14, 2012
Just purchased used tractor says
from the bottom, you have to undo the red plastic screws
5/14/2012 8:14:56 PM • Peg Perego John... • Answered on May 14, 2012
Where do i plug in
under the hood
5/14/2012 8:12:26 PM • Peg Perego John... • Answered on May 14, 2012
Does this tractor have a
there is a thermal fuse under the dash and one under the blue plastic on the battery
5/14/2012 8:09:05 PM • Peg Perego John... • Answered on May 14, 2012
When you push the gas
gear box or motor
5/14/2012 8:07:34 PM • Peg Perego John... • Answered on May 14, 2012
Peg Perego 12v John Deere tractor not working with LIFEPO4 battery.
They won't work with a Lithium battery. The controller circuitry doesn't understand this weird new battery. They don't work on electric kiddy bikes without changing the controller and then not all work as expected. They also don't work on full size motorcycles as a starting battery.
Upgrade Kids John Deere Tractor Battery in Peg Perego ...
Impact Battery https://www.impactbattery.com > blog > post > upgrad... Aug 24, 2021 - Learn how to replace your kids John Deere tractor battery and extend ride time by installing the new 12V 15Ah Peg Perego battery upgrade. .
6/1/2023 3:00:11 AM • Peg Perego Toys • Answered on Jun 01, 2023
Peg Perego Thomas The Train - Ride On wont go but horn &whistle works
If the Peg Perego Thomas The Train ride-on is not moving but the horn and whistle are still working, it's likely an issue with the motor or the gearbox. Here are a few troubleshooting steps you can try:
  1. Check the battery: Make sure the battery is fully charged and properly connected. If the battery is old, it may need to be replaced.
  2. Check the wiring: Inspect the wiring for any damage or loose connections. Ensure that the wiring is properly connected to the motor and gearbox.
  3. Check the motor: The motor may be burnt out or malfunctioning. Use a multimeter to test the motor and see if it's receiving power.
  4. Check the gearbox: The gearbox may be jammed or worn out. Inspect the gearbox for any damage or obstructions. Try lubricating the gears with some WD-40 to see if that helps.
If none of these steps resolve the issue, it may be best to contact Peg Perego customer service or take the ride-on to a certified repair shop.
2/23/2023 5:55:00 AM • Peg Perego Toys • Answered on Feb 23, 2023
Peg Perego Gaucho Super Power 24v won't run...
Once you have check the battery for power, the shifter for operation, the motors powered up to the battery, and the accelerator, the only part left is the control board. https://www.google.com/search?q=Peg+Perego+Gaucho+Super+Power+24v+troubleshooting ..
8/25/2022 7:40:45 PM • Peg Perego Toys • Answered on Aug 25, 2022
Peg perego john deere gator XUV 6x4 Stops after 10 mins then starts back after 15 mins
get a new battery that battery is failing
7/24/2021 9:01:51 AM • Peg Perego Toys • Answered on Jul 24, 2021
Peg Perego original John Deere gator has an extra plug behind the "shifter" Does anyone know what that is for?
Should be the second gear this is the owners manual also has the wiring diagram https://www.manualslib.com/manual/796621/Peg-Perego-Gator-Od0004.html?page=7#manual
4/9/2021 7:15:40 PM • Peg Perego Toys • Answered on Apr 09, 2021
I have a peg perego Gaucho A151 from the 90s. I have it running on reverse and 1st gear but second gear cuts off electric and wont run until I shift it back into 1st... then horn, lights etc all work again. What is the problem??
hello there. firstly im not very good with toy cars so excuse me if i get things slightly wrong has the car been dissasembled at all? or had the wiring changed? also does the vehicle have a PCB or is it all indevidually wired? i would personally dissasemble the car and remove the control circuit board (if it has one) and inspect it for corrosion or rust, next dose the board in White vinegar and leave to rest it will remove any corrosion on the components (scrub it with an old toothbrush if possible) also if it has connectors of some sort i would spray them with WD40 contact cleaner. lastly also spray contact cleaner into the Gear switch as that might be causing the issues...Good Luck!
7/23/2020 10:34:19 AM • Peg Perego Toys • Answered on Jul 23, 2020
My son's peg perego trail boss cuts off after he just starts to go forward. Battery is fully charged.
Maybe the gears inside it are worn down or off kilter?
6/5/2018 3:10:19 AM • Peg Perego Toys • Answered on Jun 05, 2018
Looking for Peg Perego John Deer Buck Rear Wheels. No longer stocked by Peg Perego.
Sorry we do not have parts here or any locator service to find them.
5/9/2018 8:39:43 PM • Peg Perego Toys • Answered on May 09, 2018
Peg Perego John Deere Loader Pedal Tractor Logo
Popular Tags
8 questions posted
Top Peg Perego Toys Experts
john h
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
View Most Popular
Peg Perego Toys
  • Peg Perego Toys
Most Popular Question
assembly instruction manual peg perego
  • Toys
