20 Most Recent
ATI POWERED BY RADEON 9200SE 128MB DDR WITH AGP OEM Graphic Card Questions & Answers
Salve e scusate ma non
Niente, questa scheda e troppo vecchia e non supporta win7, non ha le minime caracteristiche necessarie. To devi comprare una nuova.
I need radon 9200 128mb
I am sorry to say that ATI does not support your video card for Windows 7.
That being said some people are having good luck using Win 2000 drivers.
If you would like to give it a try I suggest reading the forum
HERE and following along with one of the working instructions posted.
Data transfer between PCs
The easiest way is with a USB data transfer cable. You just plug it into both computers, run the software and select the data to move. The sit back and in just a few minutes the data is moved. You should be able to get the cable from a local computer store, if not contact us at the address below. We have them available for shipment to you, they run $18.00 plus shipping.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
My HD 4850 fan is
Your heatsink fan on the graphic card is failing and the motor is going down hill, now saying it has completly stopped..,.. that means the fan motor is done for and need to be replaced to avoid further damage to your graphic card. Would reccommend you not using your graphic card until a new heatsink fan is replaced otherwise you can fry your GPU and suffer a complete loss.
My graphics card will not
How did you get your drivers and graphics? Did you install the whole package? What is the Asus model #? How much Ram do you have? I'm going to do a little research but let me know what you have.
Dave
HIS radeon HD 6750
Are you certain that your mainboard is PCIE 2.1 and not PCIE 2.0?
PCIE 2.1 cards like yours will not work on a 2.0 mainboard (2.0 cards will work on a 2.1 board, however) If this is the case, you will need to get a compatible card.If this isn't the case, have you tried this card in a different PC? It could also be that the card has a problem.The last possibility is that there are power issues. A couple of possibilities:
- An external power connector (6-pin PCIE direct power to the video card) is unplugged. Check and re-test.
- Your power supply (PSU) doesn't provide enough power to your graphics card & the rest of your system. Check your PSU's specs against the specs for your card. HIS recommends a minimum 450W PSU, and I would recommend a good quality Antec, Corsair, or PC Power and Cooling or Cooler Master product in the 500W range for this card.
- You got a bad card, or else it shorted out, etc. during setup or installation.
Gigabyte vga card d33006
your card is the gigabyte GV-RX195P256D-RH and you can download the drivers from here https://www.gigabyte.com/us/Graphics-Card/GV-RX195P256D-RH#support-dl-driver-vgadriver
