20 Most Recent
Little Tikes Endless Adventures Look Out Mountain Climber Questions & Answers
Little Tikes (vintage) Ride-On Train doesn't drive forward?
Question edited for clarity.
Question moved from Cars and Trucks category.
If it runs backwards, then the problem but be the forwarding part of the controller. Usually your local Model Shop will know a repairer, or they might undertake it themselves.
Trying to disassemble little tikes log cabin to no avail!!! Even searching you tube it appears such hard work and almost impossible to dismantle! Any ideas?!?
I figured out this problem today. I was ready to get a torch and saw to get it apart. It looks so simple and everything says no tools required. If your like me and bought it used, you don’t even know how it went together to reference from. So, start with the roof it’s easy to remove. For the walls I used a crowbar and brut strength. I turned it onto the back wall side. So the door should be facing up to the sky. Now, get the crowbar or something to use to get in between the roof log and the side wall log. Now pry up on the roof, push hard! The wall will slide up and break free from it’s locked together position. I quickly rejoiced and was happy when I Hurd the thunk and saw the wall moving a bit. I pulled up on the wall and quickly went back into frustration mode. But don’t fear, this is where the brut strength come in. I stepped on the wall flat on the ground and got my shoulder under the wall facing the sky. I stood up, my shoulder pushing the top wall and bam ??! One of the side wall logs jammed into the top wall came loose. After that I just kept doing the same thing and eventually was able to disassemble the rest. Two people may make this easier but I had just me and my two year old.
Tools needed: Pry bar and a strong shoulder
