20 Most Recent Fisher Price Power Wheels Barbie Jeep Questions & Answers
3answers
Power wheel wont reverse
I would call customer support and find out why the powerwheel does not go into reverse. You advised that it was the f150. I can give you the link as to where I tried to see if there might of been a safety feature of not letting the unit go into reverse. Here it goes http://www.fisher-price.com/us/powerwheels/product.aspx?pid=38040 I am not sure if it is the same one. You can also call this number Contact Consumer Relations toll-free at 888-892-6123.
We are available Monday through Friday 9 AM to 6 PM Eastern Time, 6 AM to 3 PM Pacific Time.
They might be able to tell you about your exact model.
8/18/2018 6:10:33 PM • Fisher Price... • Answered on Aug 18, 2018
My granddaughter's barbie cruisin' tunes jeep only has fast gear, no slow or reverse.
check and see if both wheels are spinning, if not you have a bad motor which would cause the other gears to not work
8/17/2017 2:51:03 PM • Fisher Price... • Answered on Aug 17, 2017
Barbie power wheel just spins doesn't move
some people stud the tires with screws, or rubber traction bands can be purchased, or just put rubber bands on the tires for indoor use
8/17/2017 2:49:25 PM • Fisher Price... • Answered on Aug 17, 2017
We have a Barbie jeep
Most auto parts store carry a load meter that will check the health of the battery. Go through the jeep first however and check that all connections are good and no wires are touching each other which would cause a dead short and drain batteries. That includes the speed pedal.
4/15/2017 5:02:55 AM • Fisher Price... • Answered on Apr 15, 2017
0answers
My daughters power wheels dont start charge battery nothing but the radio wlorks
If you're the first owner and registered it when you got it, the manufacturer website (or customer service number from website or manual) should have some answers for you. Lots of times you can look your product up on the manufacturor's website. If not, call them and ask. What's the worst thing they'll say? "No."?
11/21/2013 6:26:03 PM • Fisher Price... • Answered on Nov 21, 2013
2answers
We bought a used Barbie
I'm having the same problem would love to know if you found a solution.
11/1/2013 5:58:48 PM • Fisher Price... • Answered on Nov 01, 2013
3answers
I have a powerwheels barbie
I would suggest checking all of the connections in the wiring. Often the spade type connections can come unseated during use.
Check the following areas:
  1. Connection to the battery itself
  2. Connection to the foot switch (you may need to unscrew it from the floorboard to check)
  3. Connection to the electric motor(s) attached to the rear wheels
If the battery is older, it may have failed. If you have a multimeter, or even a simple test light, you can check to see if the battery has voltage. You're looking for around 5-6 volts. Anything below just off the charger could indicate failure.
Hope that's helpful!
7/9/2013 7:58:58 PM • Fisher Price... • Answered on Jul 09, 2013
How to test battery?
That definetly sounds like the battery.Here is a link to the power wheels batteries: http://www.mendingshed.com/powwheelbat.html
6/4/2013 11:58:27 PM • Fisher Price... • Answered on Jun 04, 2013
Can the battery be recharged before it dies or will it lessen its life by charging too often.
you can charge it whenever with a sla battery, they dont have memory like a li-ion battery
10/5/2012 4:02:31 PM • Fisher Price... • Answered on Oct 05, 2012
Change the tire on barbie jee
pop the hubcap off with a flat head screwdriver, then use a vice grip and pinch the metal push nut in half then remove
9/25/2012 2:16:51 PM • Fisher Price... • Answered on Sep 25, 2012
My daughter's barbie power wheel jeep keeps
make sure that the cogs on the tires are in tight contact with the drive motor, you might have to add some washers to take up the free space
6/14/2012 7:37:38 PM • Fisher Price... • Answered on Jun 14, 2012
Fisher Price Power Wheels Barbie Jeep Logo
Popular Tags
70 questions posted
Top Fisher Price Toys Experts
ADMIN Andrew
ADMIN Andrew
Jennifer Rock
Jennifer Rock
NOEL
NOEL
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
View Most Popular
Fisher Price Toys
  • Fisher Price Toys
Most Popular Question
test battery
  • Toys
