20 Most Recent
M-Audio Drum and Bass Rig (US15010) Questions & Answers
My M-audio FireWire 410 doesn't work
It sounds like you may be experiencing a configuration issue with your M-Audio FireWire 410 audio interface. Here are a few steps you can try to troubleshoot the issue:
- Check the connections: Make sure that the FireWire 410 is securely connected to your computer and that all cables are properly plugged in. If the connections are loose or faulty, it can cause problems with the audio output.
- Restart the device: Sometimes, restarting the audio interface can resolve issues with the audio output. To do this, disconnect the FireWire 410 from your computer, wait a few seconds, and then reconnect it.
- Update the drivers: It is possible that the drivers for your FireWire 410 may be out of date or incompatible with your operating system. To update the drivers, visit the M-Audio website and download the latest drivers for your device. Once the drivers are installed, restart your computer and try using the FireWire 410 again.
- Check the settings: Make sure that the FireWire 410 is selected as the default audio device in your operating system's audio settings. You can access these settings by going to Control Panel > Hardware and Sound > Sound. Under the Playback and Recording tabs, select the FireWire 410 and click the Set Default button.
If these steps do not resolve the issue, it is best to contact M-Audio support for further assistance. They should be able to provide you with specific guidance for troubleshooting the problem with your FireWire 410.
2/24/2023 2:16:59 PM •
M-Audio...
Answered
on Feb 24, 2023
I need a pin out diagram for audiophile 192. I wand to do myself the break out cable
Measure it myself from original card and cable.
M-Audio Audiophile 192 Pinout
DB25 Male, front view:
01 02 03 04 05 06 07 08 09 10 11 12 13
14 15 16 17 18 19 20 21 22 23 24 25
In and Monitor cables are connected to same pins (so are interchangable):
22 In L Gnd - Monitor L Gnd: iLg
21 In L Tip - Monitor L Tip: iL+
09 In L Med - Monitor L Med: iL-
08 In R Gnd - Monitor R Gnd: iRg
07 In R Tip - Monitor R Tip: iR+
20 In R Med - Monitor R Med: iR-
Main OUT:
19 Out L Gnd: oLg
18 Out L Tip: oL+
06 Out L Med: oL-
05 Out R Gnd: oRg
04 Out R Tip: oR+
17 Out R Med: oR-
Midi (Female connectors):
11 Midi Out 4 mO+
12 Midi Out 2 mOg
24 Midi Out 5 mO-
13 Midi In 4 mI+
25 Midi In 5 mI-
Midi In specifications leave Gnd pin 2 unconnected.
So connector its:
01 02 03 oR+ oRg oL- iR+ iRg iL- 10 mO+ mOg mI+
14 15 16 oR- oL+ oLg iR- iL+ iLg 23 mO- mI-
5/6/2019 3:34:47 PM •
M-Audio...
Answered
on May 06, 2019
My sound card is distorted how can i repair it
Be careful and take off the side panel to the PC tower to expose the inner parts of the computer and there you find that your sound card is inside attached to the motherboard (The Mainboard) get a star or flat head screwdriver and unscrew the screw, slowly put out your sound card (Don't forget to unplug your audio wires first) then what I do is get a Q-tip and dab it in some alcohol then just roll it on the paint leg or napkin and wipe off the little gold tips were the card slides in from BOTH SIDES and also check to see if there is a lot of dust inside your PC its pretty good that you blow it out that way it doesn't overheat as well now just put the card back in and see if that works and if not then you most likely need a driver for it and for that go to the website of the soundcard and go to support and drivers for your sound card version...Hope this helped thanks
1/1/2015 9:03:20 AM •
M-Audio...
Answered
on Jan 01, 2015
Philips mc138
Balance is adjusted with the mixer on your computer. So is the volume.
5/7/2014 4:19:30 AM •
M-Audio...
Answered
on May 07, 2014
REPAIR REPLACE MIKE IN CELL PHONE
Depends on what brand of ceel phone you have and also if you posess the necessary tools to open the phone. Mic's can be found on the web by googling cell pgone microphones.
5/7/2014 3:04:36 AM •
M-Audio...
Answered
on May 07, 2014
