20 Most Recent
Eagle Cuda 300 Compact Fishfinder Questions & Answers
One of the wires became
It's a slider connector: you need to find out from where it has popped out and simply slide it in there. Just make sure you do that with the battery off.
We have a cuda 300,
To turn on/off the simulator:
1. Repeatedly press MENU until the SIMULATOR menu appears. Press ? ?
to turn it on or off.
2. Press PWR to clear the menu.
I have a Eagle cuda
First check the Battery status of your Fish finder, replace
the battery. Check the transducer and suction-cap. Master reset after replacing
of battery may need for your fish finder. It can solve your problem.
How do you turn off automatic sonar simulation
1. Repeatedly press MENU until the SIMULATOR menu appears. Press ↑ ↓ to turn it on or off.
Simulator is after 'contrast' and before 'Language' in the list.
Where would I send an Eagle Fish Mark 640 for repairs?
I am a bit reluctant to answer this question as it may sound like I am being rude, but here goes. Type the name into google. It will tell you this is a discontinued product, and will also tell you the nearest service place to contact which will probably be a Lowrance agent. Call them and ask if it can be repaired. If so send it to them with a note explaining what the problem is. If it cannot, throw it in the bin and buy a new one. Easy.
