20 Most Recent
Humminbird 525 Fishfinder Questions & Answers
Humminbird 525 concerns , I bought a new 525 last
Is the head unit mounted near a compass, other GPS or antenna? This seems like a classic magnetic interference. Since the heads were swapped and it still functioned the same. Has the transducer been mounted with the template provided? If not, this could also compound the issue.
Stays in the display mode
Contact our customer service group and they should be able to help you out. The Humminbird Service number is 800-633-1468.
I have Humminbird 525 fish
If you have someone that has the same or simular unit just slide there control head to the base just to make sure you have enough voltage and current to power the unit. If the other unit powers up then there is a problem with the control head. Then you will need to call customer service to get it resolved.
Where is the fuse
There is not a fuse in the unit. If you want to install a fuse inline with your power cable you can go out and purchase a direct inline fuse holder.
Humminbird 215 max fish finder- Replaced batteries and now won't turn on, the batteries are good and connections are good.
Brand: DIVTEK New water bicycle - Pretty Fast. Sport Fun, Take a Deep Breath. Cool Inflatable Water Bike.Significant TIPS : Please check the FREE conveyance time prior to purchasing our water bicycles. After you consent to the transportation time, then, at that point you can submit a request. We don't acknowledge discounts on the way, Hope you can comprehend. much thanks Bike boat Up. Our Water Bikes Bike boat. A elite water bike - customary bike position. Lightweight, simple to utilize, flexibility and clean. Appropriate for: Aquatic Parks, Aqua Lakes, Rivers and ocean, and Good thought for Local Water Bikes Rental Business HIGH QUALITY: The water bicycle is made of 6061 aluminum combination outline with heating. The outside is compact and lovely. The pedal and seat both have a dependable quality. Elite: The heading control framework without paddling capacities is steady, solid and simple to keep up. The transmission framework made of a high-strength coordinated belt is both waterproof and rustproof. The buoys are physically produced using 1000D 0.9mm polyurethane covering. Your floor is furnished with light and safe scoring strips. follow the linkhttps://waterbaike.blogspot.com/2021/06/with-water-divtek-water-bikes.html
