? 2:32
https://www.youtube.com/watch?v=7Lvqp_E54Y0
Apr 13, 2015 - Uploaded by Nurul Amin
Internal Rate of Return (IRR) Calculation Using Casio MS Scientific Calculator ... +Nurul Amin i have a casio fx-82ms can ialso calculate IRR?
? 7:24
https://www.youtube.com/watch?v=Xs7rq4JI3mg
Feb 14, 2014 - Uploaded by Sujoy Krishna Das
Discount calculations on Casio fx-991ES and fx-82MS calculators .... Internal Rate of Return (IRR) Calculation Using Casio MS Scientific ...
This
calculator does not support the modulus operation directly, you have to
simulate by a divide followed by a subtraction and a multiplication.
Suppose you want to calculate 256 mod 17:
Key in 256 [÷] 17 [=] and get the result 15,0588...
Note the 15 in front of the decimal separator and key in [−] 15 [=]
That is the correct value for the cosine of 60 radians.
If you want the calculator to use some other measure for angles, press the MODE key repeatedly until you get to the "Deg Rad Gra" screen, then press the digit corresponding to your choice (degrees, radians, or grads). See "Configuring the Calculator Setup" in the second column of the first page of the manual: http://www.fixya.com/support/p1400062-casio_fx82ms_scientific_calculator/usermanual-BA0F781-pdf
You can do it the same way people did it before calculators were invented. Just use the quadratic formula: http://en.wikipedia.org/wiki/Quadratic_formula. Some sophisticated calculators have generalized equation solvers that can handle equations much more complicated than the quadratic, but the fx-82 isn't one of them.
You can do it the same way people did it before calculators were invented. Just use the quadratic formula: http://en.wikipedia.org/wiki/Quadratic_formula, and let the calculator handle the arithmetic. Some sophisticated calculators have generalized equation solvers that can handle equations much more complicated than the quadratic, but the fx-82 isn't one of them.
