20 Most Recent
Juki MO6714 Mechanical Sewing Machine Questions & Answers
Bartack machines skipping
Hello Keith, From the little information you stated, I can only take a stab at what might be wrong with your machine. I suggest you make sure the take up spring is working freely and properly.
Juki skipping stitches
completely un-thread the machine and rethread it in this order. Upper Looper, Lower looper, right needle Left needle. It has to be in that order ALWAYS. If you break a thread... un thread and start the threading process again. If rethreading doesn't work... change the needle that is skipping. Good luck
I change the news blade
hi there,
which blade you change? upper or lower one?
for lower one just make the top surface for blade aqual with throat plat.
for upper lower turn handwheel to make blade at lowest position in that time the upper lower must be lower than lower blade by arround 2.5mm and keep in your main the two blade also must be very close no space between it.
best regards
ashraf abozid
[email protected]
CAIRO - EGYPT
Question about Juki Overlock MO-6704
Someone
Hi, yes I believe that will work, however you may need to re-adjust several time to get it perfect, my wife ( who's owned a couple industrial machines agrees ) use some scrap material to make adjustments and if possible ( with machine unplugged of course ) turn by hand to make sure it is not too far and could jam. I hope this was useful, please write back to let me know-even if not so we may try to help some more. Thanks for asking FixYa, and good luck-Prodzilla
