20 Most Recent
Husqvarna Huskystar 215 Sewing Machine Questions & Answers
Where is the tension dial
It's the small, vertically oriented dial tucked next to the takeup lever. See the manual, there's a PDF you can download here.
http://www.husqvarnaviking.com/SiteMedia/Products/Machines/Support/Huskystar_207_215_manual_EN.pdf?ext=.pdf
11/2/2016 10:10:06 PM •
Husqvarna...
Answered
on Nov 02, 2016
Stitches loose and do not want to stick
You have not provided enough of a problem statement to get a good answer. (1) Has this machine ever worked well for you? (2) Are you sure you are using the right kind of thread (sometimes the shape of the thread base makes a difference (3) Have you experimented with different settings for thread tension using junk fabric? (4) Are you using the same thread in the bobbin as well as the top thread?
1/25/2015 2:56:35 AM •
Husqvarna...
Answered
on Jan 25, 2015
How does the thread on top of machine stay put
The steel piece on top should extend upward. You probably have 2, one for sewing and one for bobbin winding. It may be that the steel piece is not fully extended upward or has broken.
Hope this helps.
10/16/2014 2:31:43 AM •
Husqvarna...
Answered
on Oct 16, 2014
How does the thread holder work
It sounds like you are asking how to use the spool cap. These are put on after the spool of thread to hold the spool in place.
10/6/2014 3:49:47 AM •
Husqvarna...
Answered
on Oct 06, 2014
How to make a butten hol
This is a 4 step process. You start at the first step and it sews backwards first, Next you perform step 2 to sew the bar tack. Third you sew the right side of the button hole as it comes towards you. The final step is another bar tack which is the same as the second step.
2/8/2014 4:11:58 AM •
Husqvarna...
Answered
on Feb 08, 2014
