20 Most Recent Brother XL2600 Mechanical Sewing Machine Questions & Answers
Make sure you have not disengaged the needle bar, such as when winding a bobbin. The manual says that when a bobbin is set for winding and the bobbin winder shaft is moved to the right, the needlebar is disengaged. If that appears to be okay on your machine, perhaps something in that mechanism is broken or misaligned preventing the needlebar from operating.
http://www.manualslib.com/manual/219390/Brother-Xl-2600.html?page=19#manual
Brother XL2600... | Answered on Jan 01, 2016
It need oiling. See instruction manual.
Brother XL2600... | Answered on Jul 14, 2014
if the bobbin stitch is loose tighten the top thread tension one number at a time & sew alittle bit & if it's still loose tighten it one more number till you get the correct stitch
Brother XL2600... | Answered on Feb 11, 2012
breaking a needle a can make the machine go out of time.
and timing a machine can only be done by a sewing repair tech.
Brother XL2600... | Answered on Aug 06, 2011
You can download and print the instruction manual for Brother xl2600i in PDF format from this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Brother XL2600... | Answered on May 25, 2011
not sure where the thread is jammed but if its around the case( where you put in the bobbin) you will need to remove every last piece before you try sewing again.
Brother XL2600... | Answered on May 03, 2010
Has your machine worked before? Check that it is the correct bobbin and bobbin case. Although,if it is the spindle that is sticking out through the bobbin case, that is the shuttle. Perhaps the shuttle is not seated correctly.
Otherwise, it would probably be good to take it for service.
Brother Sewing... | Answered 3 hours ago
Brother f4 error is foot controller.
Try disconnecting reconnecting the foot controller.
Brother Sewing... | Answered 3 days ago
There are 2 ways to fix this problem. 1. go to www.sewingpartsonline.com and get the part or 2. buy a portable bobbin winder called a sidewinder (JoAnns? Amazon?) Price is around $22-$30. The part depends on what you need plus shipping.
Brother Sewing... | Answered on Oct 08, 2019
try other memory card on galaxy 2100. If other memory card read by Samsung galaxy then problem with memory card. Also check same memory card on other mobile. If memory card work fine on other mobile then problem with memory card.
http://mobile-cellphones.blogspot.com/2007/09/mobile-phones-tips-tricks.html
Brother Sewing... | Answered on Oct 02, 2019
Brother XL2600 Mechanical Sewing Machine Logo
Popular Tags
14 questions posted
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Brother Sewing Machines
Most Popular Question
needle assembly doe not go up down when
  • Sewing Machines
