20 Most Recent
Necchi 3610 Sewing Machine Questions & Answers
How do i fill bobbin, thread machine and bobbin?
Did you know all sewing machines are threaded in the same way. The parts just look a little different. If you can thread one machine you can thread them all. Dont you have an instruction book? If not get any instruction book for a simular looking machine. There are many you can dowload for free as a pdf file.
Handwheel Stuck
How about the belt? you have to take off the outer case, usually a few screws and check it. Also, when you have the case off, look for thread inside.
Necchi Q132A needle postioning dial doesn't work
If the needle positioning dial is not working on a new out-of-the-box Necchi Q132A sewing machine, it could be a manufacturing defect or a loose connection. Here are some steps to troubleshoot the issue:
- Check the manual: Make sure you are following the correct steps to use the needle positioning dial. Refer to the manual and double-check if you are using the dial correctly.
- Check the connections: Open up the machine and check if all the cables are securely connected. If any of the wires are loose, reattach them carefully.
- Contact the manufacturer: If the above steps do not solve the issue, contact the manufacturer or the seller from whom you purchased the machine. Since the machine is new, it should be under warranty, and they should be able to provide you with the necessary support or even a replacement if needed.
- Take it to a repair shop: If the machine is out of warranty, or you prefer not to deal with the manufacturer, take the machine to a reputable sewing machine repair shop. They will have the expertise to diagnose and fix the issue.
Remember not to attempt any repairs yourself as it could void the warranty or cause further damage to the machine.
Can't get my needle to tighten in my necchi nc204d
It sounds like there may be an issue with the needle clamp on your Necchi NC204D sewing machine. The fact that the needle falls out when you try to tighten it suggests that the clamp may not be holding the needle securely.
Here are a few steps you can try to fix the problem:
- Check the needle clamp: Make sure that the needle clamp is tightened properly and that the screw is secure. Also, make sure that the needle is inserted all the way into the clamp.
- Check the needle: Make sure that you are using the correct type and size of needle for your machine. The needles that came with the machine should be the correct size, but it's good to double-check.
- Check the needle plate: Make sure that the needle plate is clean and free of any debris or burrs that could prevent the needle from seating properly.
- Check the needle alignment: Make sure that the needle is aligned properly and that the flat side of the needle is facing the back of the machine.
- If the problem persists, it's best to contact Necchi customer service or a professional sewing machine technician for further assistance.
It's important to note that working with a sewing machine can be dangerous, if you're not comfortable working with it, it's best to get it serviced by a professional.
