20 Most Recent
Euro-Pro Shark Mini Mechanical Sewing Machine Questions & Answers
My machine has a problem with bobbin tension.we installed every thing as given but sometimes we are not getting any stitch
make sure the bobbin thread goes through the tension spring. if that's ok, try adjusting the little screw on the bobbin case. bobbin tension is correct if you hold it (with bobbin loaded) by the tail of the thread leaving the bobbin case. when you do that, it should hang in the air but release thread if you pull it gently. if it comes out to freely (case does not hang in air, but slides down) try turning the screw clockwise, 1/4 turn at a time til it's right. if it won't release thread without a struggle, turn the screw counterclockwise, 1/4 turn at a time. Good luck!
Bottom stitch is gathering, but I think the machine is not threaded correctly
I would start by re winding your bobbin and making sure that it is done though all the correct tension loops. A bobbin that is wound to tight or loose can cause all sorts of problems. If that has been done then completely rethread the machine from scratch. Now go through and check all your tensions, it sounds like the bobbin tension is too loose and your stitch tension is too tight. Adjust and try again.
Good luck
How to thread the machine
Hello
Place spool of thread on the spool pin, found inside the carrying handle on the top right side of the machine facing the back.
Lead thread through the upper thread guide, located just beyond the machine's handle.
Lead thread through the second upper thread guide, found a few spaces to the left of the first upper thread guide mentioned in Step 2.
Bring thread around the second upper thread guide down into the thread guide.
Lead thread toward you down through the tension discs.
Continue to pull thread down through the ****. Forming a "U" shape, bring thread back up the left side of the guide, catching the check spring as the thread moves back up through the guide on the left side.
Bring thread up to the take-up lever and insert thread through the eye of the lever in a right-to-left motion.
Lead thread downwards, slipping it down through the horizontal thread guide.
Guide thread through the wire thread guide that is attached to the needle clamp.
Insert thread through needle from front to back, pulling thread four to six inches to create a thread extension. The machine is now threaded.
I'm looking for the service Manual for an Omega Euro-Pro Serger. Model number 434D.
You can try contacting Euro-Pro directly to see if they have a service manual available for the Omega Euro-Pro Serger model 434D. Alternatively, you can try searching for the manual online through a search engine or online manual database. There are also online forums and communities dedicated to sewing and serging that may have resources or advice on how to troubleshoot or repair your machine.
