20 Most Recent Brother LB6770 PRW Computerized Sewing Machine Questions & Answers
Error Code: Check and rethread the upper thread
Yes. It is a sensor on the take up spring. If you miss threading the take up spring you get this error. If take up spring is bent or broken you get this error or if sensor is damaged this error occurs.
2/14/2015 6:32:48 PM • Brother LB6770... • Answered on Feb 14, 2015
How do I remove needle plate?
you may have to buy some small screw drivers, either at walmartor harbor freight,, they're called stubby's,, or off set screw driversthat's what I use.here's a link for a free manualhttp://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LB_6770_LB6770%20PRW_LB_6770THRD_EN_1446.PDF
9/20/2012 2:01:45 AM • Brother LB6770... • Answered on Sep 20, 2012
Lb6770 will not read card
the machine may need to be checked to see why the machine will not read the card
5/22/2012 2:25:34 AM • Brother LB6770... • Answered on May 22, 2012
My machine jammed/bent needle & gave error message
p { margin-bottom: 0.21cm; }
According to your problem, if you have change/replace the niddle properly then you can try to change the niddle position to solve your problem. Check the niddle threading and reset it. Check also the thread sensor. Reset the machine and unplug it after resetting for 2 min. Then plug it and turn it on again. If it doesn't solve your problem then you may need to reload the software.
6/8/2011 11:48:55 AM • Brother LB6770... • Answered on Jun 08, 2011
When I sew a straight stitch, my bottom thread is
try adjusting your top tension & see if that solves the problem
9/23/2010 7:57:20 PM • Brother LB6770... • Answered on Sep 23, 2010
My brother exedra e-40 #db2-b737-413
  1. In the event that changing the needle didn't determine the issue, have a go at rethreading the machine, guaranteeing legitimate pressure, and cleaning the bobbin region for any build up or garbage. On the off chance that the issue continues to happen, consider counseling the machine manual or looking for proficient help.
2/12/2024 2:00:07 AM • Brother Sewing... • Answered on Feb 12, 2024
Brother DB2-B755 Mark III-3A Sewing Machine. How do I reset 03 on my Mark 111 machine?
Question edited for clarity. A DB2 is a car made by Aston Martin, but this appears to be a sewing machine. All question need 'make model (what it is)' as first 3 words please. Question moved from Computers category to Brother Sewing. This is the only resource I can find for Brother Error 03 E03 Cause This message is displayed when the buttonhole lever is up, a buttonhole stitch is selected, and a button, such as the "Start/Stop" button, is pressed. Solution Lower the buttonhole lever before continuing the operation. https://www.google.com/search?q=Brother+DB2-B755-3A+mark+111+error+code+03 ..
2/9/2024 6:36:47 PM • Brother Sewing... • Answered on Feb 09, 2024
2answers
DOES THE BROTHER PROFILE 821 SEW LEATHER??
go to the website of leatherworker.net and check with them
1/3/2024 3:21:55 PM • Brother Sewing... • Answered on Jan 03, 2024
Brother VX-810 Sewing Machine presser foot will not go up?
Question edited for clarity add maker. Question moved to maker category. https://www.google.com/search?q=Brother+VX-810+Sewing+Machine+presser+foot+will+not+go+up ..
11/26/2023 10:26:11 PM • Brother Sewing... • Answered on Nov 26, 2023
Brother innovis 1500 D embroidery unit starts to move then chatters and stops
Hi, the only reason I can think of is that it might be the fan belt that moves the arm that is causing the problem. Best to take it in to a professional to look at it for you. Good luck
11/25/2023 3:29:34 AM • Brother Sewing... • Answered on Nov 25, 2023
Brother innovis le cant get scanned picture off previous design
Hello Tarakeira Here is an electronic manual at http://www.manualagent.com/brother/innov-is-750e/users-manual/page-10 It is for for the 750E, but will be useful for your instance. Happy Sewing
11/25/2023 3:24:34 AM • Brother Sewing... • Answered on Nov 25, 2023
Am helping a neighbor who has a cheap Brother sewing machine, the needle does not seem to be centered, the default is to the right. I can center it by changing the needle position.
Some machines do not have a centered needle as a default. That is just how they were made. If she can reposition the needle to the center, then that is a pretty good option. Most older machines with the offset needles default do not have a centering option. (I have an old Nelco that has an offset default--works just fine but I just have to remember that when stitching, the seam line will not be in the center of the presser foot.)
11/18/2023 1:45:09 AM • Brother Sewing... • Answered on Nov 18, 2023
Brother PR655 Entrepreneur Embroidery Machine. Y-axis home position error on PR655.
Question edited for a lot more clarity. Question moved from Office Equipment category. Service manual refers https://www.manualslib.com/manual/1353673/Brother-Pr655.html?page=282 ..
11/15/2023 6:48:55 PM • Brother Sewing... • Answered on Nov 15, 2023
Manual for a brother 273c
You can download required manual from this page Home Sewing Machine ' United States ' Brother support website
10/24/2023 1:38:48 PM • Brother Sewing... • Answered on Oct 24, 2023
Brother Super Galaxie 3000. How do you adjust the hook timing please?
It is a skilled job and best left to a service tech, but here is the service manual and some videos.Page 34 refers.https://acmerevival.com/wp-content/uploads/2021/07/smM3000.pdf
9/25/2023 5:07:46 PM • Brother Sewing... • Answered on Sep 25, 2023
Brother LB6770 PRW Computerized Sewing Machine Logo
11 questions posted
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Brother Sewing Machines
Most Popular Question
error code check rethread upper thread
  • Sewing Machines
