20 Most Recent Maytag MMV4203D Microwave Oven Questions & Answers
2answers
A potato caught fire and now my microwave won't
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
8/28/2023 7:03:16 PM • Maytag MMV4203D... • Answered on Aug 28, 2023
Maytag model MMV4203 display shows SE
same thing as Samsung - shorted key - google manual
2/12/2016 3:59:40 PM • Maytag MMV4203D... • Answered on Feb 12, 2016
0answers
Error code
Be the first to answer 1/21/2014 4:35:39 AM • Maytag MMV4203D... • Posted on Jan 21, 2014Be the first to answer
Maytag model MMV4230DS00, everything seems
Hi, Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....Microwave Oven Basic Troubleshooting Tipsheatman101
8/5/2011 1:57:45 AM • Maytag MMV4203D... • Answered on Aug 05, 2011
My microwave just died this morning. Not a fuse,
there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test. If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.If there is heating without any issues, you can use the microwave safely
4/5/2011 12:07:44 PM • Maytag MMV4203D... • Answered on Apr 05, 2011
The turntable in the microwave won't turn at all.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....Microwave Oven Basic Troubleshooting Tipsheatman101
11/15/2010 4:40:43 AM • Maytag MMV4203D... • Answered on Nov 15, 2010
We have installed the Micro Wave Model MMV4203D
you vent fan motor may be trying to vent upwards instead of towards tthe front of the unit, you may need to rotate motor
8/26/2010 5:55:56 AM • Maytag MMV4203D... • Answered on Aug 26, 2010
Maytag microwave that has a code of 5E or SE. The
I have the same problem. Did you get an answer? Thanks. l issa
6/21/2010 10:00:31 PM • Maytag MMV4203D... • Answered on Jun 21, 2010
E5 error code microwave
On my Microwave it saying e5 on it and it not reheating it self
11/6/2023 8:04:40 AM • Maytag Microwave... • Answered on Nov 06, 2023
Maytag oven will not heat,
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works - click here.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
11/9/2021 12:57:09 PM • Maytag Microwave... • Answered on Nov 09, 2021
Maytag Microwave Model MMV4205DB4 door switch wiring diagram
Have you checked inside the microwave? Usually they have the manual hidden in there.
2/23/2021 4:25:49 PM • Maytag Microwave... • Answered on Feb 23, 2021
Maytag (MMV5165AAS) above range microwave won't turn inside light off when door is closed.
Replace the faulty door switch.
1/30/2021 3:03:53 PM • Maytag Microwave... • Answered on Jan 30, 2021
2answers
WHAT DOES IT MEAN WHEN MY MAYTAG MMV4203DS00 DISPLAYS "SE"?
Hi, My research came up with a shorted keypad (shorted key). The part number I came up with was W10258190 this is for stainless. I hope this information helped. Good Luck I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
12/21/2019 3:08:08 PM • Maytag Microwave... • Answered on Dec 21, 2019
2answers
Hi, I have a Maytag MMV5207BCS. When i plug it in, it asks to enter the time but buttons on the key pad do not respond. Then i get an SE error. It happened in the past but unplugging on/off fixed it.
The SE error code means you have a shorting membrane keypad.
you would need to replace either the membrane keypad or the control panel frame assembly, which comes with a new keypad already installed.
unfortunately, those parts for this model seem to be unavailable. So the only option would be if you can find a used or "New Old stock" part on eBay or at a local or online appliance parts store.
If you can find either of these parts, that will fix your microwave:
DE94-01386S ASY CONTROL-PANEL (STL)
DE34-00233N SWITCH MEMBRANE (BLK)
The support page for your microwave is here, where you can find manuals and a helpful exploded view part diagram.
https://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5207BCS&siteCd=WHRCOM&userType=Consumer
Good luck.
6/30/2019 11:28:47 AM • Maytag Microwave... • Answered on Jun 30, 2019
Maytag microwave turned on and melted glass turntable,
Replace the MW
1/27/2019 11:10:44 PM • Maytag Microwave... • Answered on Jan 27, 2019
How is the diode connects to a capacitor in a maytag microwave mmv5165aas?
The service manual for model MMV5165 is here at my Web site.
12/15/2018 11:15:03 PM • Maytag Microwave... • Answered on Dec 15, 2018
Maytag MMV4203D Microwave Oven Logo
Popular Tags
23 questions posted
Top Maytag Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Microwave Ovens
Most Popular Question
maytag microwave code 5e or se
  • Microwave Ovens
