20 Most Recent Emerson Fans MW8995B Microwave Oven Questions & Answers
How do I set Clock?
Disconnect the microwave from the power source while the power is still out. If the microwave is a built-in, turn off the circuit breaker. Otherwise, unplug the microwave from the wall outlet. This prevents a power surge from damaging the magnetron tube when the power is restored.Turn on the circuit breaker or plug the microwave into the outlet only when you are sure that the power is permanently restored. If there are still storms in the area, the power may be disrupted again. Reset the clock on the microwave. Microwaves vary slightly on how to set the clock, but usually there is a clock button you press. Use the number pad to input the correct time and press the clock button again to set it. Test the microwave by heating some water to ensure that it is still in good operating condition.
3/6/2015 6:30:01 AM • Emerson Fans... • Answered on Mar 06, 2015
0answers
0answers
0answers
MAUAL
Be the first to answer 8/12/2012 4:22:36 AM • Emerson Fans... • Posted on Aug 12, 2012Be the first to answer
Micro wont heat. would like to check magnetron
Below is a link to a page with ll the info you need to diagnose the magnetronLink:
3/7/2012 1:59:59 PM • Emerson Fans... • Answered on Mar 07, 2012
Please help me locate and test magnetron on my micro
NOTE: Microwaves have a capacitor in them which can give you a massive shock!!! Be careful what you touch.You need to remove the outer metal cabinet, you will then see a large square box with fins on it, this is the magnetron.About the only thing you can check is the inline fuse inside the microwave, it will be in one of the wires that runs to the capacitor and you can check this with a multimeter . If the fuse is ok then the fault will be with either the capacitor or the magnetron, neither of which can easily be tested without specialist equipment.
3/7/2012 8:46:27 AM • Emerson Fans... • Answered on Mar 07, 2012
Hi, I cannot seem to
1-goto this page http://kitchen.manualsonline.com/manuals/mfg/emerson/mw8117w.html
2-click on the download button to download the user's manual.
plz don;t forget to vote if i solve your problem :)
1/28/2011 12:01:41 PM • Emerson Fans... • Answered on Jan 28, 2011
Microwave Bajaj 2300 ET-B circuit diagram
I need it too.
4/21/2024 7:59:40 AM • Microwave Ovens • Answered 2 days ago
2answers
I have only used my
We need just a bit more info from you please in order to possibly help you.
Model number of your steamer please. I understand the brand is TEFAL
I could pick one and give you the manual link but I don't think it would be the manual your looking for. Just being honest. Help us help you.
Thanks
Kelly
I am going to give this a shot. There are 4 Tefal steamer manuals here. Hopefully this link has your manual.
http://www.tefal.com/Consumer+service/Use+instructions/Home+Use+Instructions.htm?DdlFamily=%7B0A36B0FA-0D32-4C91-A92C-C08C22E135AD%7D
4/19/2024 5:24:25 AM • Microwave Ovens • Answered on Apr 19, 2024
Hello my Teka MCX 45.1 BIT microwaves start button not appearing?
Microwaves generally last about 2000 hours before losing power. Here are some basics to try: Make sure the power plug is securely plugged into the wall outlet. Listen for an audible click when you close the door. Unplug it, wait 30 seconds, plug it back in (this may reset it). If the start button is then not appearing, there may be a problem with the touchhpad or control panel. Teka's customer service: https://www.teka.com/global/support/
4/12/2024 5:29:50 PM • Microwave Ovens • Answered on Apr 12, 2024
3answers
I am looking for a user manual for a Mandine MMG 23 DS-17 microwave / grill
Request the manual directly from Mandine or the supplier.
4/8/2024 1:19:26 PM • Microwave Ovens • Answered on Apr 08, 2024
Amstar 1000 DGSS microwave oven user manual please?
This is not a North American make. Try the link https://www.google.com/search?q=amstar+1000+dgss+microwave+manual ..
3/30/2024 4:44:33 PM • Microwave Ovens • Answered on Mar 30, 2024
2answers
Where is the serial number on my galanz microwave air fryer ?
They are usually at the rear where the power lead goes in. This will state the maker, the address, the voltage and watts, the model number and serial number. That is a statutory requirement. In some circumstances they are in the door frame rebate but not so common where heat is involved. https://www.google.com/search?q=galanz+microwave+air+fryer+serial+number+location ..
3/15/2024 8:09:34 PM • Microwave Ovens • Answered on Mar 15, 2024
3answers
I need one c4 line microwave oven keypad where I can get it
C4_line microwave oven wich country brand
3/15/2024 8:07:28 PM • Microwave Ovens • Answered on Mar 15, 2024
2answers
What cause the high voltage fuse to damage
Based on the fact it is not said where it is used or how it blows i.e. does it blow as soon as power is applied or does it blow after a few seconds? In the first case you probably looking for direct short while in the second case a faulty item that is becoming defective when energized or hot.
3/15/2024 7:57:30 PM • Microwave Ovens • Answered on Mar 15, 2024
Cuisine Select EW1211D. Can I get a user manual please?
It is not an appliance that we know here. See how this link works for you? https://www.google.com/search?q=Cuisine+Select+EW1211D+user+manual ..
3/13/2024 5:17:14 PM • Microwave Ovens • Answered on Mar 13, 2024
2answers
My microwave just keeps beeping with a light flashing. The keypad won't work at all
You have a defective control panel (contains keyboard), it would be cheaper to just replace the oven.
3/13/2024 4:28:16 AM • Microwave Ovens • Answered on Mar 13, 2024
I have a Gaggenau microwave/owen. When I start it after a while (sometime days other times minutes) the error code E141 shows up. Lately it just shows up after a second.
this oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
ring 08705 678910 for service and advise
good luck
3/11/2024 11:07:42 PM • Microwave Ovens • Answered on Mar 11, 2024
Emerson Fans MW8995B Microwave Oven Logo
Popular Tags
4 questions posted
Top Emerson Fans Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Emerson Fans Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Emerson Fans Microwave Ovens
Most Popular Question
set clock
  • Microwave Ovens
