20 Most Recent
Jura Capresso Capresso IMPRESSA C9 One Touch Automatic Coffee Center 2Cup Coffee Maker Questions & Answers
Jura c9 on out of
You need to be patient and keep pressing the rinse button. I took a few water tanks of rinsing before it clicked over to heating mode. The manual and DVD need to mention this!
During initial startup, will not
Under the rotary switch on the left there is a micro
switch which is probably stuck in and it always pressed. That is why you enter
in RINCE directly and also it repeatedly stays at RINCE position.
So first you need to check the rotary switch and tryto slightly pull it out with a thin screwdriver very softly. If this it doesnot make any different you need to replace this rotary switch
I have been using the
Are you telling the machine that you are using the funnel and not the grinder ?
You MUST press the top left hand button on the hidden keypad so the machine does NOT grind.
Also 2 level spoons (of the jura spoon) is max you can put in the funnel.
Please dont forget to vote this answer was helpful.
Many thanks
My jura impressa c9 coffee machine keeps tellnd me
I just called their customer service 800-220-5701 with the same problem.
There's a point at the bottom of the chute where you can add ground coffee that tends to clog, especially if water gets in there. Access is from underneath - - remove the bottom tray and reach in - - it's not the hinged flap opening (that's the first thing you'll feel) but if you leave that closed and reach behind it, there's a silver-dollar sized area you're supposed to try to access and clean using a dry cloth. Once that's done you're supposed to try vacuuming from the top and then let it dry for a day or two.
