20 Most Recent
Morphy Richards 48280 FastBake Bread Machine Questions & Answers
MR Breadmaker 48268 - trips the house fuse part
I have same problem. MR breadmaker tests as OK for earth leakage, but blows circuit breaker when begins the heating cycle. Electrician advises that dust and/or moisture can make internal switches work poorly which leads to tripping of modern circuit breakers. He suggested taking it to service centre for a clean and test, but wasn't hopeful that this woudl cure the problem. Costs more to get things fixed than replace them nowadays!
Morphy Richards Fastbake makes cruching noises and debris
Hi, what sometimes happens is the drive belt snaps or comes off the pulleys underneath. If your machine has a removable panel on the bottom remove that panel and let me know if the belt is broken. If it is don't throw it away. I'll need the code # off the belt to see if I have a replacement in my stock. Email me if your belt has broken.
How too change the belt
I seriously doubt there is a belt in that unit. The unit uses direct drive through gears to turn the shaft for the paddles.
