20 Most Recent Samsung RFG297AABP (285 cu ft) Side by Side Bottom Freezer Refrigerator French Door Questions & Answers
Refrigerator does not cool, freezer is working fine
Model Number?
6/6/2019 9:22:51 PM • Samsung... • Answered on Jun 06, 2019
Ice cubes clumping up
sounds like ice tray over filling
6/3/2015 3:45:23 PM • Samsung... • Answered on Jun 03, 2015
0answers
The water dispenser just trickles
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/24/2011 1:50:11 AM • Samsung... • Answered on Aug 24, 2011
The ice-maker is not making ice at its regular
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
7/28/2011 8:14:31 PM • Samsung... • Answered on Jul 28, 2011
I have a Samsung RFG297AABP
Hi.
If the leak is not too big, then water comes from condensation. Water condensing inside the fridge is supposed to be conveyed toward the drain hole inside the fridge. From there the water should normally go to the drain try located in the compressor assembly.
What usually happens is that the drain hole gets clogged with frozen water, and the condensed water ends at the bottom of the fridge. The problem is fixed defrosting the fridge. In some sporadic case it is necessary to remove drain hole blockage using a thin and flexible drain rod.
Do a complete defrost, that should fix the problem.
Here all parts and diagrams for this fridge.
Regards.
Ginko.
4/15/2011 10:15:17 PM • Samsung... • Answered on Apr 15, 2011
Hi I have a Samsung fridge model DA99-01221D . My freezer is cooling well but fridge is not cooling at all please help
Check the Control Settings: Ensure that the temperature settings for both the fridge and freezer compartments are appropriately configured. Sometimes incorrect settings can lead to cooling problems. Make sure the fridge is not in demo mode. If it is, disable demo mode by referring to your user manual. Inspect the Door Seals: Damaged or worn-out door seals can cause cold air to leak out, resulting in insufficient cooling in the fridge compartment. Inspect the door seals for any cracks, tears, or gaps. If you find any issues, consider replacing the door seals. Evaporator Coil and Fan Check: The evaporator coils in the fridge play a crucial role in cooling. If they are frozen or malfunctioning, it can affect cooling. Similarly, check if the fan responsible for distributing cold air inside the fridge is working correctly. Reset the Refrigerator: Sometimes a simple reset can resolve cooling issues. Unplug the fridge from the power source for a few minutes, then plug it back in. Observe if there's any improvement in cooling after the reset. Compressor Overheating: You mentioned that the compressor is very hot. An overheated compressor can impact cooling. Allow the compressor to cool down completely before switching the fridge back on.
4/1/2024 3:42:13 PM • Samsung... • Answered on Apr 01, 2024
2answers
I have a Samsung Refrigerator Model RS261MDRS/XAA 01 that stopped cooling.
Check the coolant level and pressure when cooling. You may need to evacuate the system and reload it with the correct anount of gas.
3/31/2024 8:48:13 AM • Samsung... • Answered on Mar 31, 2024
2answers
The refrigerator makes a loud noise when the compressor turns on.
Compressors are noisy due to its job. Check there is no packaging between the motor and any other part as that can increase the noise.
3/11/2024 2:58:26 AM • Samsung... • Answered on Mar 11, 2024
3answers
Cool select pantry on Samsung RFG297HDRS keeps beeping (as if being pressed), even when doors are closed.
The make appears to be known for beeping. Try a power reset. Pull the wall plug for 5 minutes. https://www.google.com/search?q=Samsung+RFG297HDRS+cool+select+pantry+keeps+beeping Video
3/9/2024 5:52:04 AM • Samsung... • Answered on Mar 09, 2024
Fans in both refrigerator and freezer of Samsung RF4287 HARS-xaa are not working. Replaced evaporator fan motor in fridge and it is still not working. Help, please!
could be just the coil on the valve, but most more likely valve getting stuck as it opens. somtimes can take apart and clean, will work for awhile, but if have the cash best just swap it out. will save you hassel down the road.My Aplogies I was under the impression you had already located the valve. I as I have not seen unit I can not give the location, However since it is on the water system, I would trace water tubing from where it connects to unit. It should not be far from inlet connection. Look for tubing going to a valve with wires ontop, ensure after the valve is where you whish water/ice to come out. Once that is located take photo and order new valve, or secure water remove and clean valve. Note have container ready as water will leak once you remove valve.
1/25/2024 4:41:01 PM • Samsung... • Answered on Jan 25, 2024
Our Samsung refrigerator model RFG297ACRS is not cooling and freezer not cold.
First I would clean all grim. Second if you do not have refrigerant gauges feel discharge line with hand. Will be a smaller line and coverd with foam. It should be hot to condensor. if not You probabaly lost charge. Also top of compressor should be hot. Should the above not meet specs. You need to find leak, get a pro. to locate repair leak, as you need licenese to go further.
1/24/2024 9:51:02 PM • Samsung... • Answered on Jan 24, 2024
3answers
Evaporator fan new but not working on samsung rs267lash
Manny MANY unfortunate customers who bought this **** from Samsung have problem.
Specifically the Freezer cold but fridge side no lower than 55deg problem.
It is a known defect that Samsung has not taken ownership of. I have the same problem with the same model as many.. if you search the net. Iv'e been trying to find a designated website for repairs for this problem. Please post website with solution if anyone finds it. Thanks
1/24/2024 8:45:56 PM • Samsung... • Answered on Jan 24, 2024
We have a Samsung SRS702GDHSS fridge freezer after a power outage the control panel reads88 88 and none the buttons respond
Unplug the fridge, wait 2 minutes and plug back in. If symptoms remain then likely it was damaged. If you don't have a whole house surge suppressor then you need one. Modern appliances are extremely susceptible to voltage spikes.
12/31/2023 5:18:31 AM • Samsung... • Answered on Dec 31, 2023
Samsung fridge freezer not freezing properly
First: i don't know. In the manual there should be some pages for solving dysfunction and what the lights mean. Always check for damage on the closed and pressurized system, including inside, where the tubular radiators are, mostly half within the panels. Those may have broken when using tools to remove ice or been hit rough with some object. For a right understanding: the fridge must not be shaken or tilted and carried. When this has happened, then the evaporation fluid or refrigerant can be mixed with the oil that resides on the bottom of the compressor. It may only have a small sponge to clear the fluid from a little oil contamination. What finally solves the mixing is shutting the fridge off for 24 hours and when not completely satisfied with the result, immediately for another 24 hours. Another thought is that a fridge may not function at all, in a cold room. Transfer of heat is totally not the same at all temperatures. Many people have been the same disappointed as you, thinking they can find a cold place for the fridge or freezer. So, when this has happened when the room temperature dropped dramatically, get it out of the cold or shut it down because it performs at its maximum capacity. That is where my bet is at. The radiator at the back can also not function right when it is close the wall and/or an object is placed right above it. The heat must be dispersed. Best of luck
11/20/2023 5:46:53 AM • Samsung... • Answered on Nov 20, 2023
How do I get my Samsung fridge rs267td to stop beeping
temp too warm if temp is ok by checking with thermometer then replace temp sensor
11/18/2023 8:57:19 AM • Samsung... • Answered on Nov 18, 2023
Samsung refrigerator display RD code. How to fix please.
Question edited for a lot more clarity. Please proof read before Posting.. Question moved from Cellphones category. 40,000 to choose from RD is air damper iced up fault. The damper in the freezer spins around to close/open the air from the freezer to the fridge. It ices up from time to time, or the damper motor, or sensor that reads it's position fails. Apr 27, 2010
Hi. My samsung RL39WBMS fridge/freezer shows rd in the ...
If you can spell it, you can Google it! Lots more in the link. 'make model (what it is)' in all questions please. https://www.google.com/search?q=Samsung+refrigerator+RD+code ..
10/22/2023 5:53:54 AM • Samsung... • Answered on Oct 22, 2023
Samsung RS20 fridge freezer. The freezer is not freezing, white soft ice inside and defrosting now.
Question edited for clarity and typos. When they regassed it, they didn't check where the leak was. It is still leaking and you have lost gas again. https://www.google.com/search?q=Samsung+RS20+fridge+freezer ..
10/17/2023 4:58:55 PM • Samsung... • Answered on Oct 17, 2023
Samsung RFG297AABP (285 cu ft) Side by Side Bottom Freezer Refrigerator French Door Logo
15 questions posted
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Refrigerators
Most Popular Question
refrigerator not cool freezer working
  • Refrigerators
