20 Most Recent Fisher and Paykel E522BRXFDU (176 cu ft) Bottom Freezer Refrigerator French Door Refrigerator With Ice Box Questions & Answers
3answers
Water from dispenser is not cold
Did you let water run through dispenser long enough for air to get out of lines and for reservoir to completely fill?
11/12/2023 10:20:42 AM • Fisher and... • Answered on Nov 12, 2023
0answers
The ice cube tray only
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
9/3/2011 11:46:34 PM • Fisher and... • Answered on Sep 03, 2011
3answers
Hi, I have a Fisher and Paykel E402B
the defrost heater or thermostat located on the evaporator coil thats icing up isnt defrosting due to a bad heater or thermostat,or it can be the defrost timer that powers these other 2 parts
3/24/2024 3:44:13 PM • Fisher and... • Answered on Mar 24, 2024
Fisher and Paykel fridge E521T is not cold enough?
If your Fisher and Paykel E521T fridge isn't cooling properly, check the temperature settings, clean the condenser coils, ensure proper ventilation around the fridge, and inspect the door seals for any leaks. If issues persist, consider contacting Fisher and Paykel customer support or a professional technician for assistance.
1/8/2024 1:07:40 PM • Fisher and... • Answered on Jan 08, 2024
I moved a fisher and paykel upside down fridge freezer to a new house, I turned it on a half hour after it was in my new home but it has not gotten down to a cold enough temp, if I turned it on too so
It is possible damage will result. Your fridge's compressor motor is suspended inside the compressor housing on three or four springs. These springs are designed to hold the motor load in a vertical position. Transporting a fridge on it's side can stretch or break these springs which can cause a shudder stop condition (the fridge makes a shuddering banging noise everytime the compressor stops and sometimes when it starts). It's a good idea to let a fridge sit for a bit anytime it is moved. Over night won't hurt but an hour is more than enough time. the internet consensus seems to be that you should limit the amount of time the unit is not upright. And as stated above, leave it upright at least overnight before starting it. Apparently damage can arise from mixing of lubricant and coolant, so damage is more likely in an older unit with worn seals.
6/24/2023 10:15:39 PM • Fisher and... • Answered on Jun 24, 2023
Fisher & Paykel N510T. How to replace lightbulb in it please?
Question Edited for clarity, FULL maker name. Question moved top correct category. See page 48. It is just a standard screw in MES appliance bulb. https://spares.bigwarehouse.com.au/images/files/19463_8a6cceaa9082dd9036a69da66cd5adcf.pdf $15.75 https://spares.bigwarehouse.com.au/product_info.php?cPath=64658_64659_64692&products_id=1618505 If it has a cover, there is a video here https://www.google.com/search?q=fisher+and+paykel+fridge+n510t+replace+bulb+replacement ..
8/14/2022 3:56:15 PM • Fisher and... • Answered on Aug 14, 2022
My F&P E372B fridge freezer starts beeping with the doors properly closed.
It is an alarm state, either it thinks the door is open or the temperature is not within specs. check the door gaskets are sealing properly? Your best bet is to get a service visit.
1/23/2022 8:31:56 PM • Fisher and... • Answered on Jan 23, 2022
Fisher Paykel F/F N3958 overflow seems blocked in fridge causing pools of water
Edited question to correct spelling of 'Fisher', as they aren't German. ;>) Moved category from Washing Machines to Fisher Paykel Refrigerators. Videos on how to unblock the drain https://www.google.com/search?q=fisher+paykel+fridge+blocked+drain ..
10/17/2021 1:06:21 AM • Fisher and... • Answered on Oct 17, 2021
How do I fix a F2 Fault on my refrigerator - Fisher and Paykel Refrigerators
The F2 code on the active smart model relates to an EVAP SENSOR RESISTANCE FAULT which means the resistance of the Evaporator Sensor is outside of the normal range (> 45k ohms). In the first instance - Check sensor connection at the controller but if that does not resolve the problem then the sensor would need replacing.
5/8/2021 2:06:42 PM • Fisher and... • Answered on May 08, 2021
20 beeps when i open my fisher and paykel fridge. I changed the spring on the door hinge and now it beeps when ever i open the door.
Turn the Fridge OFF at the power socket, wait 10 seconds and turn it back On. If still beeping, You will need a Service Technician to assist with this. See the site below for more help or to schedule a tech visit.
3/27/2020 2:44:40 AM • Fisher and... • Answered on Mar 27, 2020
2answers
My fridge freezer is leaking due to condensation at the top of the fridge.
Try blowing compressed air up the drain tube.
1/4/2020 7:44:11 AM • Fisher and... • Answered on Jan 04, 2020
2answers
How can I access the defrost heater on my fisher and paykel "active smart" fridge?
HEY!!!!! If your breaker is tripping it means you have a short circuit - a serious safety issue. Unless you are a qualified electrical tech, for safety reasons refer this one to a pro.
10/18/2019 10:02:57 AM • Fisher and... • Answered on Oct 18, 2019
Fisher and Paykel E522BRXFDU (176 cu ft) Bottom Freezer Refrigerator French Door Refrigerator With Ice Box Logo
11 questions posted
Top Fisher and Paykel Refrigerators Experts
Grand Canyon Tech
Grand Canyon Tech
NOEL
NOEL
john h
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher and Paykel Refrigerators
Most Popular Question
water from dispenser not cold
  • Refrigerators
