20 Most Recent Electrolux EI28BS56IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator Questions & Answers
I had the typical issue
It would need to be checked at the main board to see if the sensor is ok. then the wires need to be checked one by one from the sensor to the main board to see if there is a problem with a wire inside the cabinet (non repairable).
2/12/2018 11:08:25 PM • Electrolux... • Answered on Feb 12, 2018
SY EF code on display. Where can I get directions for replacing evaporator fan motor?
Lower freezer section.
4/6/2016 3:00:51 AM • Electrolux... • Answered on Apr 06, 2016
The Ice machine wont produce ice.
here are some things to try first before calling repair person. unplug the unit, if you can remove the unit , do it., IF NOT, JUST REMOVE THE ICE TRAY UNIT, leave unplugged for 30 minutes. make sure the water is following, see if you get cold glass of water, this means the system has water, and IF NOT, check the line frozen or damaged, after 30 minutes plug the unit back in, install the ice tray properly secured in place, make sure the leaver flush against the ice maker it may take 1 hour or more and go look see if it producing ice if it is not producing ice than call a repair person.
10/2/2015 5:02:20 PM • Electrolux... • Answered on Oct 02, 2015
Why is the refrigerator section not cooling?
Sounds like a defrost problem,either bad defrost heater or bad defrost thermostat
7/28/2015 3:04:52 PM • Electrolux... • Answered on Jul 28, 2015
0answers
How do I get ice from model #E128BS561S5?
25297176-1xulv4qsxv1r1rrcaio2eatt-5-1.jpg I hope this page from the manual helps. It might be that you must hold down the button for 3 seconds as stated in the manual, or a stuck bale arm. Otherwise, it may be a bad feed valve to the ice maker.
11/26/2014 12:42:03 AM • Electrolux... • Answered on Nov 26, 2014
0answers
French door
Be the first to answer 3/18/2014 3:51:22 AM • Electrolux... • Posted on Mar 18, 2014Be the first to answer
0answers
3error code
Be the first to answer 1/22/2014 3:31:03 AM • Electrolux... • Posted on Jan 22, 2014Be the first to answer
0answers
Control housing
Be the first to answer 12/29/2013 3:03:47 AM • Electrolux... • Posted on Dec 29, 2013Be the first to answer
2answers
Electrolux Ref. 3yrs old. ice maker will not make
Hi,either your fill tube is clogged or the water valve in the back of the refer has failed. Go to the back of the unit, if my memory is correct the yellow hose is for the ice maker, at the water valve disconnect the 1/4 hose from the valve to the ice maker only, place valve in a bowl, cycle ice maker. If you get water, fill tube is obstructed, if not water the valve has failed and needs to be replaced.Good Luck I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
12/19/2013 12:43:11 AM • Electrolux... • Answered on Dec 19, 2013
Ice Melting towards the front of the ice hopper
Check that the fan motor wiring has not been disturbed. If the freezer fan is not working, the fridge will generally start cooling but due to poor air circulation , it will stay colder at the back but will get warmer at the front hence causing the ice to melt. The usual temp for a food compartment is around 4 degrees. The freezer should be -18 degrees celcius.
11/25/2013 11:13:58 PM • Electrolux... • Answered on Nov 25, 2013
2answers
Power outage while away caused
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
8/5/2013 7:18:44 PM • Electrolux... • Answered on Aug 05, 2013
The cooling fan Inge the freezer is not running
Hi James, thank you for your question! If the cooling fan is not functioning properly, then your refrigerator could possibly be experiencing a seal system issue. Let's try resetting the unit by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn the unit on. If the issue persists, regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
8/3/2013 6:36:52 PM • Electrolux... • Answered on Aug 03, 2013
0answers
Electrolux EI28BS56IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
53 questions posted
Top Electrolux Refrigerators Experts
ZJ Limited
ZJ Limited
vince
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Electrolux Refrigerators
Most Popular Question
sy ef code display indicates evaporator
  • Refrigerators
