20 Most Recent LG LFC25770ST (250 cu ft) Bottom Freezer French Door Refrigerator Questions & Answers
0answers
The arm in the ice maker is stuck in the "up" position
unplug the unit and check if the icemaker timer is working alright. replace with a new one if it is messed up. thanks .
3/5/2016 5:03:46 AM • LG LFC25770ST... • Answered on Mar 05, 2016
Noise/vibration when doors are open.
Are the legs adjusted solid to the floor?
8/3/2015 1:23:49 AM • LG LFC25770ST... • Answered on Aug 03, 2015
0answers
0answers
Looking for manual
You may download the manual and more from here.
7/1/2012 7:54:30 AM • LG LFC25770ST... • Answered on Jul 01, 2012
Lg ice sticks together
hi luke.possibly water over flowing or leaking in.turn water off and try first.hope it helps.Ali
6/25/2012 8:24:33 PM • LG LFC25770ST... • Answered on Jun 25, 2012
Need ice maker parts breakdown AEQ36756907
Hi.The icemaker AEQ36756907 is sold as a single part. For this reason the manufacturer (LG) does not provide a diagram with the exploded view of the ice-maker assembly (here part). A diagram with the icemaker position in the whole fridge assembly is available in the service manual. Here an example with the same icemaker shown at page 49 in position 600A.Regards.GinkoOther models are similar.
12/15/2011 1:19:15 PM • LG LFC25770ST... • Answered on Dec 15, 2011
The ice maker is not
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
9/20/2011 11:40:37 AM • LG LFC25770ST... • Answered on Sep 20, 2011
LG LFC25770ST (250 cu ft) Bottom Freezer French Door Refrigerator Logo
41 questions posted
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
looking manual
  • Refrigerators
