20 Most Recent
Powerware PW9150 12.5KVA/8.75KW (pf1221114ue0010) UPS System Questions & Answers
Which Battery to use...
I think the existing battery will be a 12V 26Ah type. You can use any brand 12V/26Ah batteries. Make sure you are using the same number and you connect them in the exact manner and polarity as the old battrey bank.
Ups drops load at unpredictable times. battery is
If the load is dropped then there is a serious fault with the ups, even if the inverter fails, it should go to bypass and not drop the load.
Sound like a control fault, I suggest you need a ups tech.
This equipment has many dangerous parts inside. Batteries are always live and very dangerous. The boards are stuffed the surface mount components.
You need an approved service agent, who should be able to help
