20 Most Recent Frigidaire FPGS3085KF Stainless Steel Gas Range Questions & Answers
Why did oven quit working and displayed F12 error?
Hey Renee, I understand that you are receiving an "F12" error message on your Frigidaire Gas Range. Before considering contacting a service provider, I would recommend resetting the range by turning off the power to the appliance for about five minutes. After the five minutes return power to the appliance, this should allow the washer to return to working condition. At this time if you find the problem still persists, you may want to consider contacting a professional technician. The concern could be the control board. Hope this helps! -JK
10/29/2015 2:19:21 PM • Frigidaire... • Answered on Oct 29, 2015
Igniters always on with a fridgedaire duel fuel range?
You should have a professional diagnose this. This unit should not have any clicking or ignitors on while not in use.
1/6/2013 7:51:08 PM • Frigidaire... • Answered on Jan 06, 2013
The power control for the
first check the breaker, then make sure your getting power to the oven if you are getting power ( 240 watts ) and still no display on the panel then you will need to get a new ERC board which is the control board/clock.
4/9/2011 2:19:06 AM • Frigidaire... • Answered on Apr 09, 2011
3answers
Oven flame on Frigidaire GCRG3060AFH on recently converted to propane is to high
did you install the conversion kit correctly ---you just cant change the lines from natural to propane need correct conversion kit
1/20/2024 10:35:00 AM • Frigidaire... • Answered on Jan 20, 2024
How do I turn the volume down or turn off the beep from my Frigidaire Gallery 5.0 cu. ft. Gas Range when the oven reaches its intended temperature?
As copied from the manual. Setting a silent control panel When choosing a function, a beep will be heard each time a pad is pressed. If desired, the control can be programmed for silent operation. Press and hold (start/time) . After 7 seconds, the control will beep once. This will block the controls from sounding when a pad is pressed. To return the sound, press and hold (start/time) again for 7 seconds until the control beeps once NOTE! The OVEN indicator light on the electronic display will turn ON and OFF when using the Bake feature and during preheat. This is normal and indicates that the oven is cycling to maintain the selected baking temperature. When the preheat indicator light turns OFF, your oven is ready.
11/24/2023 7:11:46 PM • Frigidaire... • Answered on Nov 24, 2023
15answers
Beeping F11 error on Frigidaire
Hi im an appliance tech and i had the same problem its not the EOC other words control board its actually the speed bake swith its stuck in the on position that why you get a stock keypad error code either f1 or f11 replace that switch or disconnect it and im positive that this will solve it .
10/31/2023 8:53:27 PM • Frigidaire... • Answered on Oct 31, 2023
The oven in my relatively new frigidaire gas range lights up runs then turns off a minute or two later
Yes you cannot run propane on a nat gas range differant burner injector sizes and differany working pressures. It will not work .
10/20/2023 10:22:03 AM • Frigidaire... • Answered on Oct 20, 2023
Where is the fuse located on a Frigidaire range?
8/31/2023 5:33:59 AM • Frigidaire... • Answered on Aug 31, 2023
Frigidaire glass top stove big burner burned out but a new one but the connections are totally different from the old one how do I wire in the new burner please help
Send it back and get the correct one. It can't be the same part number if the connections are different. Your old one may have features that his new one doesn't. The one less wire may just be a shared return, but the stove might be needing individual returns. If it is an updated replacement (the listing sometimes says 'compatible with' or 'replaced by', or 'alternative part'), it should come with a wiring schematic. Please always include full 'make MODEL (what it is)'. Fixya Expert 'Jorgie the Appliance Guy' will have the answer if it is a shared return but he will need the model number. Edit your post and add it. ..
7/27/2023 1:07:06 AM • Frigidaire... • Answered on Jul 27, 2023
How to I adjust the flame in a Frigidaire gas oven.
No orifice for the oven jet? All work on gas appliances needs to be done by a certified gas technician. Somewhere, normally just behind the knob, there is an adjusting screw (certainly for hobs). The flame must be high enough that it can't blow out. The standard test is the slam the oven door, with your kitchen windows closed and then again with them open. Help in the link, but also the pressure from the tank _at_ the range should be checked. https://www.google.com/search?q=oven+flame+adjustment ..
7/8/2023 5:04:18 PM • Frigidaire... • Answered on Jul 08, 2023
The oven and broiler elements are not working in my older Frigidaire stove. I suspect a blown fuse.
This is so confusing You say "The oven and broiler elements are not working" Then you say "Everything works except the burners'. so nothing works? No oven/broiler elements and no burners? It make me wonder what the 'everything' is that works? The clock? The oven light? Sounds like the main house breaker has flipped. On my older GE stove from the 1980s there are glass screw in fuses hidden below the controls and above the hobs. You undo the switch bezel for the oven light and the switch bezel for the rotisserie and pull the panel forward exposing 8 fuses. If all yours blew, it would be very strange! Click comment under my answer and also under Vince's and we will get you Fix-Ya.
6/2/2023 3:57:46 AM • Frigidaire... • Answered on Jun 02, 2023
2answers
Why is my Frigidaire Gallery electric range turning on by itself?
some ideas here, but you will probably need a service call.
6 Reasons Why Frigidaire Oven Turns on By Itself
https://missvickie.com > frigidaire-oven-turns-on-by-itself Jun 2, 2022 - 1. Auto Timer. The latest models of Frigidaire ovens are coming with some innovative and futuristic features, and setting the timer is one such ...
2/13/2023 7:33:03 PM • Frigidaire... • Answered on Feb 13, 2023
2answers
Oven flames too high on newly converted gas stove.
yes sounds like you missed the oven burners at the bottom of unit
1/4/2023 3:24:00 AM • Frigidaire... • Answered on Jan 04, 2023
What is F29 error on Frigidaire professional gas range
F29 on all Frigidaire ranges means there is a communication error between the oven user interface and the touch panel. The control can't do the initial communication. This could be related to a wiring problem or a problem with the touch panel or the oven user interface board. Turn off the power to the range for 30 seconds to clear the code. If it returns, check that the wiring harness is fully seated. Check the wires for continuity and make sure that there is no corrosion on any of the pins. If the error repeats, replace the touch panel. If the error still persists, then replace the user interface board. Please add a comment with the model of the range for a parts list/diagram. I hope this helps. Cindy Wells
12/9/2022 12:59:42 AM • Frigidaire... • Answered on Dec 09, 2022
2answers
Frigidaire Induction Stove Top Keeps Locking
Hi, please make sure that there is a pot or pan on the stove top when you start it. It might be locking as a safety mechanism if it doesn't sense an object ready to be heated. Otherwise, please refer to the troubleshooting section of you manual to help turn off the locking mechanism. Thank you.
11/19/2022 6:09:53 AM • Frigidaire... • Answered on Nov 19, 2022
2answers
My frigidaire oven bake or broil wont heat up stove top is fine
Good Afternoon James, I appreciate your post! Based off the information you have provided your Frigidaire range will not bake or broil but the cooktop is working properly. This could be a potential issue with your control panel or elements. Since it could be anyone of these underlying issues I would suggest having a professional technician out to perform a proper diagnosis and repair. Having a technician out will prevent any unnecessary part purchases. Best of luck! -Matt
10/23/2022 8:52:13 AM • Frigidaire... • Answered on Oct 23, 2022
Frigidaire FPGS3085KF Stainless Steel Gas Range Logo
7 questions posted
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Kitchen Ranges
Most Popular Question
oven quit working f12 error alarm kept
  • Kitchen Ranges
