20 Most Recent Nor-Lake KLF7766C Commercial Freezer Questions & Answers
sounds like a bad defrost terminator or timer wired wrong. won't make temp as the evap is not clear of ice/frost build up. check your wiring diagram for location and operation of terminator.
Nor-Lake... | Answered on Jun 26, 2017
Most likely there is a charge issue. A low charge could create the issues you are having.
Also, a faulty or defrost clock could also create issues if the system is freezing up.
Nor-Lake... | Answered on Feb 10, 2015
I would start there. If the thermostat has an off setting, turn it there and see if it goes off. If not, try turning it to it's warmest setting while the box is cold to see if it turns off. To test to see if the relay/ contactor is stuck/bad, kill power to the unit (Unplug or turn off breaker). Disconnect one wire to the thermostat. Restore power. If unit runs, bad relay/contactor. If unit does not run, I'd replace the thermostat. Make sure the sensing bulb of the thermostat is in the conditioned space of the box or in the return air (intake) side of the evap so it can sense the box temp.
Nor-Lake... | Answered on Aug 21, 2010
start with checking the freon level. If too low, the txv will open and try to feed the evap. this can cause some overfeeding and give you some frost in some cases. It could also be a txv not feeding correctly. usually and overfeeding condition. causes frost build up on line and compressor and pressure in evap too high to remove the heat needed to properly cool. If a cap tube system, usually a sign of over charged or a real dirty condenser. In both cases, an evap fan, not properly working will cause a freeze up of the evap causing a high box temp and frost build up on the line and compressor.
Bad fan delay switch.
Nor-Lake... | Answered on Jul 23, 2010
L1 goes to 1-2 on Clock, L2 or Neutral to N on Clock, Defrost heater to 3 on Clock, Defrost Limit/Fan Delay to X on clock
Nor-Lake... | Answered on Dec 12, 2010
I have a generic wiring diagram that I use on all my installs that works very well. It is basically the same for most all commercial walk in freezers. Send me a email address and I'll scan and forward what I have.
Nor-Lake... | Answered on Oct 16, 2010
either the cold control thermostat is defective or the rtc overload contactor has welded itself together and cant open and close the power contacts to the unit,un plug the cold control and see if the unit stops then
Nor-Lake... | Answered on Feb 27, 2010
You can't predict when you will have the legendary cards. Just keep playing and sometimes you receive a legendary card. Good luck!
Clash Royale Guide
Freezers | Answered 3 days ago
https://www.gumtree.com.au/s-miscellaneous-goods/machine+operators/k0c18319
Find machine operators ads in our Miscellaneous Goods category. Buy and sell almost anything on Gumtree classifieds. Try here.
Freezers | Answered on Apr 16, 2019
The problem with laying down a fridge or freezer is the compressor lubricating oil can leave the compressor and enter the refrigerator tubing. It is best practice to allow these appliances to stand upright for a period before switching on to allow the oil to run back into the compressor.
Some people say four hours is sufficient and some say six hours. I suppose if some logic was injected into the situation it would depend of how long transportation has taken and the longer it has been horizontal the longer it should stand idle...
Freezers | Answered on Apr 13, 2019
Nor-Lake KLF7766C Commercial Freezer Logo
6 questions posted
Top Nor-Lake Freezers Experts
Dennis Boxerman
Steve Allison
Steve Allison
Are you a Nor-Lake Freezer Expert? Answer questions, earn points and help others
View Most Popular
Nor-Lake Freezers
  • Nor-Lake Freezers
Most Popular Question
commercial freezer cycle off lot lately
  • Freezers
