20 Most Recent
Braun Series 1 190 Electric Shaver Questions & Answers
Diode laser hair removal is better than IPL or DPL?
All the details Anna, starting with the conclusion.
CONCLUSION. To conclude, diode lasers are better for hair reduction and pigmentation removal, while IPL lasers can be more versatile and can address a wider range of skin concerns. The choice between the two will depend on the specific needs and goals of the patient.
Jan 31, 2023
IPL vs Diode Laser Hair Removal - Cosmeditech
Cosmeditech
https://www.cosmeditech.com > News > Blog
Diode Laser Hair Removal VS. IPL ...
Spotless Laser
https://spotlesslaser.com > blog > diode-laser-hair-remo...
Diode laser hair removal is more comfortable because of the integrated cooling and treats more hair and skin types, whereas IPL is best suited for those with ...
The Difference between IPL & Diode Laser Hair Removal
Oxford Laser Aesthetics
https://www.oxfordlaseraesthetics.co.uk > Blog
The treatment methods outlined above mean that, typically, IPL technology will require more regular and long-term treatments for hair reduction, while diode ...
Difference between IPL, DPL, SHR and Laser Hair Removal
bioaesthetic.com.sg
https://bioaesthetic.com.sg > ufaqs > what-is-the-differe...
Aug 10, 2020 - Even though DPL is an advanced form of IPL, it is effective and quick in hair removal when compared to IPL. It removes all the gentle and small .
Braun Battery dead How do disassemble it
Braun Series 3 Electric Razor disassembly and battery replacement (original and AA NIMH batteries) (youtube.com)
Braun 9-in-1 Trimmer - Disassembly/Battery Replacement (youtube.com)
Remove the Screws: First, you'll need to remove any screws that hold the device together. Look for visible screws on the casing or housing. Use the appropriate screwdriver (usually a Phillips or Torx) to carefully unscrew them.
Open the Casing: Once the screws are removed, gently pry open the casing. Be cautious not to damage any delicate components inside. You can use a flathead screwdriver or a plastic opening tool for this step.
Access the Battery: Inside the casing, you'll find the battery. Depending on the specific Braun device, the battery may be soldered in place or connected via a connector. If it's soldered, you'll need to desolder the connections. If it's connected via a connector, carefully disconnect it.
Replace the Battery: If you have a replacement battery, insert it in place of the old one. Make sure to observe the correct polarity (positive and negative terminals). Secure the battery back in its position.
Reassemble the Device: Put the casing back together, aligning all the components properly. Screw it back in place.
Test the Device: Once reassembled, check if the device powers on. If it does, congratulations! You've successfully replaced the battery.
Braun Series 9 Clean and Charging station not working.
The short beep and LED on indicate that the Braun Series 9 charging and cleaning station is receiving power, but is not working properly. First, make sure the station is charged. If the station is charged, but still not working, try unplugging it and plugging it back in. If it still doesn't work, review the user manual to see if there are additional troubleshooting steps, or contact us for assistance. As for the Nakamichi 680ZX deck, the half-speed rotation speed indicator should light up when the rotational speed is selected in the middle. If this does not happen, the drive may be damaged and would need to be repaired.
My Braun Series 7 shaver drops out shavings rather than catching them in the shaver head. How do I fix this?
I have used one of these for over 10 years, and never had it leak shavings unless I am shaving the top of my head after shaving my face. You say you regularly use the cleaning station. It needs cleaning of shavings after every use. I remove the head and tap the shaver and head over the sink after every shave. About every two weeks, I rinse the foil and clean the cutter and shaver top with an old toothbrush and soapy water and leave it to dry.
Braun Thermoscan 6022 is not switching on. Used it perfecto last night, this morning it's not working. Changed batteries... still nothing
If your Braun Thermoscan 6022 thermometer is not switching on even after you have replaced the batteries, there could be a few possible causes:
- Battery installation: Make sure that you have inserted the batteries correctly, with the correct polarity. Check the battery contacts for any corrosion or debris and clean them if necessary.
- Battery type: The Braun Thermoscan 6022 requires two AA alkaline batteries. If you have used a different type of battery, such as rechargeable batteries, this could be the reason why the thermometer is not turning on.
- Battery life: Even if the batteries are new, they could be defective or may have run out of charge quickly. Try replacing the batteries with a fresh set of AA alkaline batteries.
- Reset: Try resetting the thermometer by removing the batteries for at least one minute and then reinserting them. This can sometimes help to reset the internal electronics of the thermometer.
- Faulty thermometer: If none of the above steps work, it is possible that the thermometer itself is faulty. In this case, you may need to contact Braun customer support for further assistance or consider purchasing a new thermometer.
