20 Most Recent
Philips arcitec 1060 Electric Shaver Questions & Answers
To charge
Men\'s Grooming / Norelco1-800-243-3050Monday - Saturday 9:00 AM - 9:00 PM ESTSunday 9:00 AM - 6:00 PM ESTExcluding Major Holidaysgood luck
Please see the question below. Will the RQ12 head work?
Yes, the RQ12 type heads will work on Arcitec model 1060X. However, your original cap will not fir the RQ12 heads. If you have a cleaning machine, using the RQ12 heads will make it incompatible with the cleaning machine also
I have 3 red lights
It's means that you change new replacement heads. That philips arcitec 1060 electric shaver replacement heads is
Norelco RQ10 shaving replacement heads.
A red light is on
It's menas that you change new replacement heads. That philips arcitec 1060 electric shaver replacement heads is
Norelco RQ10 shaving heads.
How do you remove the
The Arcitec series shavers have a very poor design and shaver heads can not be disassembled like the older model that you had. The blades can not be removed from the assembly that contains them. The only way to clean them is to run thm under hot water or ren them in an alcohol solution. Unfortunately, this method still leaves much to be desired.
Many users of the Arcitec models report having to change the heads twice as often because of this.
Complains can be made to Norelco customer service at 1-800-243-3050 If replacements are needed, you will find then at shaveroutlet.com. See link below http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
