20 Most Recent
Google Nexus One Smartphone Questions & Answers
I have a new Nexus
Drag down the notification bar, click the Cog, and the language option has an A icon next to it.
Am trying to use 3
Firstly you need to make sure that the phone is unlocked i.e. it is not tied to another network. Secondly, perform a manual network search. You do this by going into your menu and selecting: (i)settings, (ii) network services, (iii) network selection, then (iv) manual. It will then search for available networks: click on any network first, and then go back into it again and click on Lebara. If that still does not work try the SIM in a different handset.#
Lebara Customer Service
Restarat
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
How do i transfer from my orbic phone from my google photos to my fire hd 10
To transfer photos from your Orbic phone to your Fire HD 10 tablet, you can use a few different methods, such as:
- Connect your phone to your tablet using a USB cable and transfer the photos directly.
- Use a cloud storage service, like Google Photos, to upload your photos to the cloud, and then download them to your tablet.
- Use a file transfer app, such as AirDroid, to wirelessly transfer the photos from your phone to your tablet.
- If you have your Google photos app installed on your Orbic phone, you can share the photos from google photos to your fire hd 10 using the share feature in the google photos app.
My Google services frame work notification keeps appearing, can't use my phone. How can I remove it?
Solution 1 - Update Google Play Services to the latest version. You can download from here. You may be getting an error because you have a very outdated version or the one you have is having a conflict/bug with the current Android version in your phone.
Solution 2 - Clear the Google Play Services cache. The Google Play Services app in your phone acts like a framework for all the Google and Google Play apps installed in your phone. You can try cleaning up its cache and see if that would fix the issue. This worked with one of our team members! Read these quick and easy steps :
Go to Settings > Apps.
Scroll to All apps and then scroll down to "Google Play Services" app.
Open the app details and tap on the "Force stop" button.
Then, tap on the "Clear cache" button.
Solution 3 - Clear the Google Services Framework cache. The Google Services Framework system app on your Android device stores information and helps your phone sync with Google servers - and keeps your Google Play Services up and running. This could be one of the reasons why you are not able to connect to Google servers using the app and keep getting the error message. Read these quick and easy steps :
Scroll to All apps and then scroll down to "Google Services Framework" app.
Solution 4 - Check your Internet connection. May be your WiFi network is blocking any of the IP addresses that Google use. You can also try switching the WiFi on or off on your phone - same with mobile data.
Solution 5 - This goes without saying, but may be a simple reboot of your Android phone/tablet could fix the problem.
Solution 6 - I hate to say this, but in the end, you might just want to install a custom ROM that is stable with no bugs.
Hope this helps
