20 Most Recent
ION Audio TTUSB 10 Vinyl Recording USB Turntable with Audacity Software Dust Cover and Analog Stere Questions & Answers
How do I recovery temporary files in Audacity ?
If you are on Windows you can get it to display hidden files (such as system files) With luck it might show up your missing files. Just type "show hidden files" in the help on Windows and follow the instructions.
My turntable appears to be uneven. it looks like a rolling hill when spinning, can this be fixed
Is it just the matt that records sit on that's the problem or the whole platter?
If it is the matt you can peel it off and get a new one from somewhere such as as Amazon. It doesn't have to be the same brand as the turntable as long as it fits on.
Just search for "turntable matt".
If the platter is the problem it might be caused if the platter is plastic by either a chemical or heat warping the platter. Has it been exposed to the sun for example? Some chemicals such as oil and polish can cause it to bend out of shape.
It's likely if the platter has warped that it will need to be replaced.
Rumbles badly, unable to play.
Adjust the weight on the end of the arm, till the rumble sounds stops, but the stylus stays in the groove. It's trial and error doing this I'm afraid.
