20 Most Recent
Audio Technica ATLP120USB Turntable Questions & Answers
Too much bass
I didn't know that a turntable had bass control on it. If it has why not turn the bass down? I think it is your receiver not the turntable
No right side chanel sound
reverse the phono cables to see if the other side goes out if it does you could have a bad cable or the wire is off at the catridge.
My turntable doesn't rotate any more...
Hi, the transformer that supplies power to the motor has been fried by the 220v input and will need to be replaced. If you remove it and go to your local electronic parts supplier they should be able to sell you a replacement. Cheers John styluscity.com
A week after I bought
Just turn up the weight on the arm slowly bit by bit till the problem stops. The weight should have numbers on it - set it at 2 and increase it. You will have to stop the record playing each time you increase the weight. Also look around to see if it has an Anti-skate control, if it has again increase that in stages. It's all down to trial and error setting up a turntable, there's no correct way and it depends also on the records too and quality of them.
