20 Most Recent Nike Imara Fit WR0076-002 Wrist Watch Questions & Answers
2answers
How do we reset the time?
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch here.
12/14/2022 8:31:58 AM • Nike Imara Fit... • Answered on Dec 14, 2022
2answers
How can i set up a nike bowerman wrist watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all NIKE watch manuals. Rate me, please.
12/14/2022 8:31:10 AM • Nike Imara Fit... • Answered on Dec 14, 2022
0answers
Change day
Be the first to answer 12/8/2011 4:40:08 PM • Nike Imara Fit... • Posted on Dec 08, 2011Be the first to answer
0answers
How can i set up a nike bowerman hand clock
3/15/2010 9:30:45 AM • Nike Imara Fit... • Answered on Mar 15, 2010
Bought this watch for my daughter for xmas and
Go to the web site "nike timing".
Select "region"
Select "support"
Enter your model on the "Manuals" box.
The info you need should be here.
1/3/2010 4:02:31 PM • Nike Imara Fit... • Answered on Jan 03, 2010
Does anyone have instructions for Nike Imara Fit WR0076?
How to set time(hour minutes)/date(day, month, year)/power hour on nike imara fit:
PLEASE READ CAREFULLY
STEP 1:
First hold the button for set/light.
STEP 2:
wait for the "hold to set" message to appear
once it appears, keep on holding the button until the hour is ready to be set or when the hour blinks.
TIP: Pressing the mode will enable you to choose from setting (HOUR, MINUTE, DAY, MONTH,YEAR, 12/24 HOUR FORMAT, POWER HOUR.)
STEP 3:
To set HOUR: press the start(for higher values) or stop (for lower values) button, choose whatever hour you want to set the time.
*If you are done setting the time press the set/light button, and there you have it.
If you still need to change the minutes of your digital watch proceed to step four.
STEP 4:
After, you have undergone step 1, & 2, or step 1, 2, & 3 (either way it'll still work), press the mode button and then, minute is ready to be set or when the minute blinks.
To set MINUTE:
press the start (for higher values) or stop (for lower values) button, and choose whatever minute you want to set the time.
*If you are done setting the minute, press the set/light button, and there you have it.
If you still need to change the date specifically, the day of your watch proceed to step five.
STEP 5:
To set date, specifically, DAY:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode twice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode once.
To set DAY: press the start (for higher values) or stop (for lower values) button, and choose whatever day you want to set the date.
*If you are done setting the day, press the set/light button, and there you have it.
If you still need to change the date specifically, the month of your watch proceed to step six.
STEP 6:
To set date, specifically MONTH:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode thrice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode twice. If you did it step by step until 6, press the mode once.
To set MONTH:
press the start (for higher values) or stop (for lower values) button, and choose whatever month you want to set the date.
*If you are done setting the month, press the set/light button, and there you have it.
If you still need to change the date specifically, the year of your watch proceed to step seven.
STEP 7:
To set date, specifically YEAR:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode four times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode thrice. If you skipped step 6, press the mode twice. If you did it step by step until 7, press the mode once.
To set YEAR: press the start (for higher values) or stop (for lower values) button, and choose whatever year you want to set the date.
*If you are done setting the year, press the set/light button, and there you have it.
If you still need to change the 12/24 hour format of your watch proceed to step eight.
STEP 8:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode five times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 4 times. If you skipped step 6 & 7, press the mode thrice. If you skipped step 7, press mode twice. If you did it step by step until 8, press the mode once.
To set 12/24 HOUR FORMAT: press the start (for higher values) or stop (for lower values) button, and choose whatever format you want to set the time.
*If you are done setting the 12/24 hour format , press the set/light button, and there you have it.
If you still need to change the power hour of your watch proceed to step nine.
STEP 9:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode six times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 5 times. If you skipped step 6, 7, & 8, press the mode 4 times. If you skipped step 7 & 8, press mode thrice. If you skipped step 8, press mode twice. If you did it step by step until 9, press the mode once.
To set POWER HOUR: press start for 3, 6, 12, 24 to set the power hour.
Press set/light to set POWER HOUR.
5/26/2009 3:34:46 AM • Nike Imara Fit... • Answered on May 26, 2009
How do I set the time for nike imara fit
STEP 1:
STEP 2:
STEP 3:
STEP 4:
To set MINUTE:
STEP 5:
STEP 6:
To set MONTH:
STEP 7:
STEP 8:
STEP 9:
5/26/2009 3:20:28 AM • Nike Imara Fit... • Answered on May 26, 2009
Looking to repair a damaged NIKE OREGON WATCH ALTIMETER, DIGITAL COMPASS MODEL # WA0018-001
Repairing a damaged Nike Oregon Watch Altimeter and Digital Compass (Model # WA0018-001) may require some technical expertise and specialized tools. Here are some steps you can take to repair the watch: 1. **Assess the Damage**: Examine the watch carefully to identify the extent of the damage. Determine which components are affected and what repairs are needed. 2. **Consult the Manual**: If you have the user manual for the watch, review it to understand its features, functions, and specifications. The manual may also provide troubleshooting tips or instructions for common issues. 3. **Contact Nike**: Reach out to Nike customer support or visit their website to inquire about repair services or replacement parts for the Oregon Watch Altimeter and Digital Compass. They may be able to provide assistance or recommend authorized repair centers. 4. **Professional Repair**: If the damage is extensive or requires specialized tools or expertise, consider taking the watch to a professional watch repair technician or a Nike authorized service center. They can assess the damage and perform the necessary repairs using proper techniques and equipment. 5. **DIY Repair**: If you have experience with electronics and watch repair, you may attempt to repair the watch yourself. Depending on the nature of the damage, you may need to replace components such as the screen, battery, or sensors. Be sure to use appropriate tools and follow safety precautions when working with electronic devices. 6. **Replacement Parts**: If certain components of the watch are damaged beyond repair, you may need to source replacement parts. Check online marketplaces, watch repair shops, or specialized retailers for replacement screens, batteries, straps, or other components. 7. **Follow Safety Precautions**: When repairing electronic devices, always disconnect the power source and handle components carefully to avoid further damage or injury. If you're unsure about how to proceed or if the repair seems too complex, seek professional assistance. By following these steps and taking appropriate precautions, you can attempt to repair your damaged Nike Oregon Watch Altimeter and Digital Compass or seek professional assistance if needed.
4/25/2024 5:42:17 PM • Nike Watches • Answered 3 hours ago
I have a Nike WC0045 the battery died on it.I replaced battery and it only lasted 3 days.
I am very sorry to hear that news, just dreadful :>( I was trying to find out who actually makes this watch, but there is no data. Normally you send to the maker and they repair it. My late wife bought me a Seiko, and although I live in Canada, I send it to the UK where it was purchased and where the service centre is for servicing. you could ask Nike who was contracted to produce it? My guess is Casio, because it has the Casio look to it. One thought I have is that the battery that was put in it was the wrong type or it was inadvertently replaced with a battery out of another watch that came in for repair. I would have another battery put in it and see what happens. It is actually a collectible watch. https://www.google.com/search?q=Who+makes+Nike+WC0045 There are a few ideas which battery is the correct one https://www.google.com/search?q=nike+wc0045+watch+battery+replacement ....
8/25/2023 3:47:40 AM • Nike Watches • Answered on Aug 25, 2023
Replacement WA0056-6D3 Lance Alti Chrono watch band.
Try contacting Nike or a good watch retailer for the replacement band. Sadly, we do not supply parts we just give advice for repairs.
5/16/2023 10:36:19 AM • Nike Watches • Answered on May 16, 2023
How do I set the time on my Nike imara watch?
https://www.fixya.com/support/t1871132-set_time_nike_imara_fit
7/1/2021 11:18:05 PM • Nike Watches • Answered on Jul 01, 2021
Nike led watch manuel
3/26/2018 11:49:10 AM • Nike Watches • Answered on Mar 26, 2018
Nike Imara Fit WR0076-002 Wrist Watch Logo
12 questions posted
Top Nike Watches Experts
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
ADMIN Eric
ADMIN Eric
Are you a Nike Watch Expert? Answer questions, earn points and help others
View Most Popular
Nike Watches
  • Nike Watches
Most Popular Question
set up nike bowerman hand clock
  • Watches
